Recently got this Saab 9-3 on a trade.
The ad stated:
1200 OBO or Trade
CAR RUNS BUT NOT VERY WELL IT EITHER NEEDS A FUEL PUMP OR A THROTTLE BODY. California car "not one spot of rust"
Brand new-
* Turbo "STIGAN" not a cheap China
* Tail lights
* stage 3 tuned ECM by mps
* DO88 larger intercooler and hoses
* 3 inch turbo back exhaust
* Magnaflow muffler
* Tires *1200 miles on them*
* Emblems
* Intake
* Boost controllers
* Oil cooler
* Front shock bearings
* Sway bar end links
* waterpump and timing chain guides
* Thermostat and housing
* Rear window motors
* Coolant lines
* Intake, throttle body and all exhaust gaskets
* Valve cover gaskets
* Performance igntion coils and spark plugs
Interior is mint.
Everything works as it should
Needs-
* Front window motors
* Windshield, has small crack along bottom. unless i do it.
The guy said it had a new head gasket. When i first started it up no white smoke, but the oil seemed a little milky.
Fast forward a week start it up to pull the check engine codes to start looking into the hard starting and rough idle issue. Cranks about 15 times, fires up and then a bunch of white smoke, then maybe 2 mins later no real smoke to speak of and it is idling seemingly ok.
So i pop the cap of the radiator expansion tank, no bubbles but fluid looks pretty dirty and there are wafts of "smoke" coming out of the tank.
My plan was to part it out and use the engine for challenge purposes, but if the head gasket is blown my plan to to part it out, and keep the "upgrade parts" Turbo, intercooler, coils, injectors.
So any way it isn't the head gasket? If there is a chance that it is not, what is the best way to test?
