Wow. I'm in love.
I've had a 94 in my fleet for a few years that at least started its life pretty similar to this one (Regular cab/short bed/3.9/Auto). From the get go, it's duties have basically been to haul crap and be a 2nd vehicle for my now fiancee from sometime in April/May to October/November, then sit while salt is on the roads. I eventually swapped it to a 5.2 V8. After that, burnouts were added to it list of responsibilities.
Aside from maybe a Geo Prizm I had a long time ago, my Dakota has been the cheapest and most reliable vehicle I've ever owned.
I LOVE these trucks.
Here's my thoughts (and this would mostly be for 92-96 examples)...
The good:
-Aside from fuel, cost of ownership is hilariously low. Plates, insurance and most replacement parts are super cheap.
-Super easy to work on
-With the V6, I didn't think the fuel economy was that awful given what it was... I got around 17 in what was nearly 100% city driving, and managed to creep over 22 on a road trip with a much larger than average passenger and a bed full of car parts. In comparison, I had a 2.3/5speed single cab RWD '92 Ranger that barely got 20 while being painfully slow. I also had a 2011 Ranger RWD/Single Cab 2.3/Auto that got 24 in about 95% highway driving, albeit with a cap and a decent load in the bed.
-It really isn't much worse with a V8. before I added some bolt ons it did about 14/15 on 87 in almost all city driving. Now it's like 13/14, but on 93 required by the Mopar PCM.
-RWD V8 examples are more fun to drive than you'd expect... or at least that's what people tell me when I let them borrow mine and insist they beat the snot out of it.
-What the 3.9 lacks in power, efficiency and smoothness, it makes up for in reliability. The radiator on mine split on one of the hottest days of the summer a few years ago. It wouldn't hold anything and I was kind of looking for an excuse to add two more cylinders, so I just drive it home running like crap with the temp gauge pegged. I put a new radiator in it just so I could move it around my property and it ran excellent. It continued to do so for another 2-3 years before I pulled it at 197k to swap in a 5.2 V8. Just about anyone I've ever known that had a 3.9 Dakota abused the E36 M3 out of them, had well over 200k and never complained. I actually felt bad pulling it out and only got $20 from some guy who finally hauled it out of my garage.
-The A/C was probably the best out of all my vehicles up until around 198k, when it started to lose and no longer hold a charge
-I find the interior to be a good bit roomier than the Rangers I had
-While the interior is pretty craptastically plastic and cheap.... FWIW, other than the headliner, mine's held up far better and is a lot more rattle free than a lot of the same era and even newer Big 3 vehicles that I've owned
-If you get bored with the V6, swapping to a V8 is a breeze. It's also pretty much guaranteed you'll find every part you need in one trip to the "You Pull" junkyard which are always littered with various Dakotas, Durangos, Rams and Ram Vans.
The Bad:
-They love to rust. Mines been in the salt belt it's whole life and while the frame and floors on mine are fine, the fenders, rockers, cab corners and bed sides went to E36 M3 probably sometime during W Bush's 2nd term. The PO filled each with bondo and gave it a Maaco job that made it just passable for the well under $2k I paid for it. I've also got a cab mount perch that rotted through, but I just spray it with WD40 every once in a while to shut it up.
-The auto transmissions are a known weak spot. That said, I've never really worried about it because they're all over the place in the junkyard and you can get ugly running and driving examples for a fraction of what a rebuild or a new trans would cost. FWIW, the 197k mile old trans behind my 3.9 started popping into neutral from drive. Instead of looking into it, I just bought a cosmetically challenged running and driving V8/Auto example (with the same electronics/fuel setup - IE 92/93, 94/95, 96) for $400, swapped the engine/trans/ECU/harness into mine and scrapped the rest. Adding an auxiliary trans cooler is usually a good idea.
-While it's passable for part time use, short trips to the JY or store, or my 20-30 minute commute to work every once in a while. I'd trade the single cab for an extended cab if I had to live with it on a regular basis. My engine/trans donor was an extended cab and the liveability was night and day.
-I've run into a few parts that are NLA and had to be sourced from the JY: Control Arms, Wiper and shifter linkage parts, body bushings and a few others I've forgotten.
-While it was a V6, I think I had to drive it in light snow once and with an empty bed it was pretty frightening. Now with the V8, it's scary in the rain. I don't even want to know what it would be like in snow...
-I've always hated the O/D with both transmissions and both engines that have been in the truck. Makes the truck drive like crap unless I'm going over 55MPH. I usually click the button to shut it off unless I'm getting to ready to go on the highway.
-If you look at 2000 or newer examples, steer clear of that disaster 4.7 V8. While it's more efficient and fun to drive (especially with a manual and RWD) than the ancient 5.2, it's the complete opposite in terms of simplicity and reliability.
All that said, and with as much as I love Dakota's, $7k is WAY more than I'd ever pay for one. For me to even spend $3k on one it would have to be:
-A clean Shelby
-A clean R/T
-A SUPER clean 92-96 that checks a lot of boxes in terms of engine/trans/options/etc.
-Have a clean title
Here's mine with a couple of my other E36 M3 boxes:
