madmrak351
madmrak351 HalfDork
9/5/24 9:37 p.m.
This was on a friends front suspension with a mustang II front suspension swap. We need a similar fastener at least one inch longer.
madmrak351
madmrak351 HalfDork
9/5/24 9:38 p.m.
madmrak351
madmrak351 HalfDork
9/5/24 9:41 p.m.
Straight shank no taper on either side.
44Dwarf
44Dwarf UberDork
9/5/24 9:51 p.m.
I'd start with Speedway motors
madmrak351
madmrak351 HalfDork
9/6/24 8:11 a.m.
I have looked. Everything I have found that is reasonable close is tapered on the short side of the collar. Also called AllStar performance, they did not have any idea. The long side goes through a mono ball on the upper A arm. The short side goes into the upper part of the knuckle. Seems like that should have been a taper however the knuckle was reamed straight.
RacingComputers
RacingComputers HalfDork
9/6/24 12:33 p.m.
Just a short in the dark, but Grainer has a lot of this type of stuff.
Might be worth a look
Toyman!
Toyman! MegaDork
9/6/24 1:00 p.m.
A machine shop should be able to turn one out fairly easily.
madmrak351
madmrak351 HalfDork
9/6/24 1:28 p.m.
In reply to RacingComputers :
Thanks I will try them.
madmrak351
madmrak351 HalfDork
9/6/24 4:32 p.m.
Currently waiting on a response from Coleman Racing. They are looking to see if they can match it up with something.
madmrak351
madmrak351 HalfDork
10/3/24 6:32 p.m.
Coleman custom made a set for me. I tweaked a few of the dimensions in addition to the length and ended up with a good fit.
dG53SHhkUXCWLThSlhoLETlcLu5Bjy4SDqoMN0UThHbG3qkotM5JppRpeqhD7pBL
