spitfun
spitfun New Reader
3/27/13 11:09 p.m.
I have a question.Just finished my rotary powered Spitfire (RotoSpit) autocross car. Anybody have any suggestions for camber settings? The car has been lowered (about 3" off the ground now at the frame) and I am using Avon bias slicks. Thanks Rich
scardeal
scardeal Dork
3/28/13 7:30 a.m.
Glad to hear you finished it. It's looking good.
emodspitfire
emodspitfire Reader
3/28/13 8:10 a.m.
swing axle or custom rr susp?
What size wheels and tires?
What is the weight dist?
kb58
kb58 HalfDork
3/28/13 10:32 a.m.
Or just set it to -1 deg and either watch tire wear or temperature across the tire face. Don't over-think it.
spitfun
spitfun New Reader
3/28/13 11:49 a.m.
In reply to emodspitfire: The tires are 8x13x20 with 8" wheels. It does have the stiffer,decambered swing spring setup. As far as weight distribution,the rotary/transmission combo I figure is pretty close to the stock combo-so whatever a stock spit is!!. Thanks Rich
spitfun
spitfun New Reader
3/28/13 11:53 a.m.
In reply to emodspitfire: I read the specs on your car. Good to see you are using the stock Triumph diff,I added a Quaife to mine along with race axles and have nowhere near the torque you have so it should be fine. Rich
noddaz
noddaz HalfDork
3/28/13 12:17 p.m.
Don't think you can just get away with the pictures in your profile...
Cough em' up. We know you have more information than that.
(Shines bright light into spitfun's eyes)
We want the story. The WHOLE story...
Scott
spitfun
spitfun New Reader
3/28/13 1:24 p.m.
In reply to noddaz:I added a few more pictures to my garage. Unfortunately I don't have any in action as I haven't driven it yet. Rich
erohslc
erohslc HalfDork
3/28/13 3:46 p.m.
What's your driving style?
Too bad you have the swing spring.
A fixed spring with Camber Compensator gives you more adjustability.
Minus 1 front/rear is a good start.
If it understeers, increase front neg camber, up to -4 max.
If it oversteers, lower the rear to increase neg camber, up to -4 max.
spitfun
spitfun New Reader
3/28/13 5:50 p.m.
In reply to erohslc: Sorry,I DO have a fixed spring not a swing. Rich
PjE6z8JRit8UXSRrqvzsLtTH3UrA1uNxvHt0DxcZZJPGnzrGCgr5CnWCg0SPLYVw
