oldtin
oldtin SuperDork
2/16/12 9:45 p.m.
I'm waffling between seats for the MGB GT - between kirkey pro streets, corbeau forza or clubman or ultra shield spec miata. I've driven an mx5 cup car with sparco evos - comfy for a two hour stint but outside the budget.
edit - looks like the corbeaus aren't legal with NASA without going to the FX1
What does the GRM knowledge base say?
Keith
Keith SuperDork
2/16/12 11:42 p.m.
I've got FX1 Pros. I've always found that Corbeaus sit a bit high. But the big thing I did to them for comfort was to substitute Backsaver foam for the stock bottom cushion. Massive difference, and I'd consider it for just about any race seat I own.
It's expensive stuff from Pegasus, but it's not so expensive elsewhere:
http://www.scs-interiors.com/aerospace/foam-products/confor-foam-cf4-medium-blue-1.html
spnx
spnx New Reader
2/17/12 6:15 a.m.
Keith wrote: I've got FX1 Pros. I've always found that Corbeaus sit a bit high.
This is true. I had to chop and re-weld the seat bracket for my Corbeau. Also, the seat brackets used to be made by Wedge Engineering.
"engineering" should be a loose term, since it looks like they eyeballed where the bolt holes should line up, rather than measured.
chandlerGTi
chandlerGTi HalfDork
2/17/12 7:00 a.m.
This is true. I had to chop and re-weld the seat bracket for my Corbeau. Also, the seat brackets used to be made my Wedge Engineering. "engineering" should be a loose term, since it looks like they eyeballed where the bolt holes should line up, rather than measured.
All true, pretty good seats though.
Moparman
Moparman HalfDork
2/17/12 8:13 a.m.
I have a Corbeau Forza. As others have posted, it does sit a bit high. When I first sat in it I was not happy. However, when I first took the Neon out on an autocross course, I absolutely loved the perspective. I could see the course better. Fortunately, the Neon has much headroom and I am only 5'11"
spnx
spnx New Reader
3/11/12 8:20 p.m.
At 6'1", I couldn't fit in my car with a helmet, with the Corbeau Forza. I was not amused.
It's getting pretty worn, so I'm thinking of using it as an occasional passenger seat and using a Kirkey for the driver's side.
yq8dI1iyxyveoibjjRDtNQVGeLxffYwe6eosfVoMBi9nNAiiYV5oJYUuea7Q48KV
