pilotbraden
pilotbraden Dork
12/30/11 2:25 p.m.
http://www.bangshift.com/blog/Car-Feature-The-Secret-Weapon-A-1980-Olds-Wagon-With-496ci-of-Vortec-Big-Block-and-a-Doug-Nash-5-Speed.html
This is quite a machine. It seems to be traction limited.
fasted58
fasted58 SuperDork
12/30/11 2:32 p.m.
perfect sleeper
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
12/30/11 2:34 p.m.
Beyond awesome!!!
Javelin
Javelin SuperDork
12/30/11 2:42 p.m.
Droool!
mtn
mtn SuperDork
12/30/11 3:13 p.m.
So much want
xflowgolf
xflowgolf New Reader
12/30/11 3:13 p.m.
absolutely fantastic.
DoctorBlade
DoctorBlade Dork
12/30/11 3:34 p.m.
What'd those poor tires ever do to him?
RealMiniDriver
RealMiniDriver Dork
12/30/11 3:55 p.m.
I need one of those.
Hoop
Hoop SuperDork
12/30/11 4:11 p.m.
Needs more Caprice.
amg_rx7
amg_rx7 HalfDork
12/30/11 4:12 p.m.
Friend of mine had one of those. Rattle can flat back. With a turbo. And leather buckets from a 300zx. And 17x10 wheels w/ big meats. Cool.
novaderrik
novaderrik Dork
12/30/11 5:06 p.m.
that's the best use i've ever seen for one of those engines.. but he needs to figure out a way to plug the hole in the hood- the cheesier looking the better.. perhaps some sort of a tacky stick on hood scoop from the local PepZone..
thunderzy
thunderzy Reader
12/30/11 10:43 p.m.
Been wanting to build exactly that for years now!!! So awesome!! Now all I need to do is find a manual trans g-body
novaderrik
novaderrik Dork
12/31/11 12:06 a.m.
thunderzy wrote: Been wanting to build exactly that for years now!!! So awesome!! Now all I need to do is find a manual trans g-body
good luck.. most of them were junked years ago and took their pedals and bellhousing with them..
there is a company that makes reproduction clutch linkage parts for them now, and some people have used slightly 80's F body and S truck clutch pedals.. that only leaves the bellhousing, which had the pivot ball in a weird location for whatever reason.. but if you go with a hydraulic clutch, you only need to source a junkyard pedal and whatever bellhousing you want to run.
singleslammer
singleslammer New Reader
12/31/11 12:34 a.m.
That is quite the vehicle. I wouldn't see it coming
Strike_Zero
Strike_Zero Dork
12/31/11 7:35 a.m.
oh my yes. . . .
driver109x
driver109x HalfDork
12/31/11 7:50 a.m.
Forget boner pills... this car will do
familytruckster
familytruckster Reader
12/31/11 9:24 a.m.
too bad it doesn't ft under the hood. Looses the sleeper look with an engine sticking out the hood.
Ranger50
Ranger50 Dork
12/31/11 9:39 a.m.
Needs more woodgrain peel-n-stick. Less crappy 8.1L nonsense.
novaderrik
novaderrik Dork
12/31/11 10:13 a.m.
Ranger50 wrote: Needs more woodgrain peel-n-stick. Less crappy 8.1L nonsense.
you are entitled to your opinion and i totally respect it, even if it's terribly wrong in every way.. except for the wood grain- yes, it needs woodgrain.
The_Jed
The_Jed Reader
12/31/11 10:56 a.m.
I can't think of a better use for a derelict 8.1.
The_Jed
The_Jed Reader
12/31/11 10:58 a.m.
I'd like to have one of those.
Ranger50
Ranger50 Dork
12/31/11 10:59 a.m.
In reply to novaderrik:
Never have a driven a bigger pos then when it has the 8.1 in it. Oil burning, gas guzzling, gas trans shifting strategy POS.
hotrodlarry
hotrodlarry Reader
12/31/11 11:25 a.m.
Most of the g-bodys I've seen have the knock out panels in the floor for the shifter and pedals. hardest part is finding the parts. I had a '87 Cutlass 2 door that had a 3 speed manual trans. It made a boring car fun to drive.
Billy_Bottle_Caps
Billy_Bottle_Caps Reader
12/31/11 3:12 p.m.
That video is sweet..
novaderrik
novaderrik Dork
12/31/11 4:36 p.m.
Ranger50 wrote: In reply to novaderrik: Never have a driven a bigger pos then when it has the 8.1 in it. Oil burning, gas guzzling, gas trans shifting strategy POS.
i've only known a couple of people that have had 8.1 powered trucks, and their experience was the opposite of yours.. one of them lost his 6 month old 8.1 powered 2500HD crew cab in a flash flood and got a same year Duramax as a replacement and was disappointed.. the 8.1 pulled his gooseneck loaded tractors to various tractor pulls without complaint and the Duramax just didn't have the oomph the 8.1 had..
but either way- this car weighs at least a ton less than anything that engine came in stock and who cares if it burns a little oil? a torquey big block backed with a stick shift in a 3500 pound car is a winning recipe even if you gotta keep a few extra quarts of oil in the back at all times..
9RAm8otrZ1I6FXG2rho0qvTPXg60lLEUW1A8xnKoLjrsxKGubZPBumzitf9WFEqo
