kevinh333
kevinh333 Reader
12/6/21 3:40 p.m.
Apologies, not sure where to post this so I did so here and in the "shop and garage talk" forum.
Hoping for some help, I thought this would be an easy topic to research but it seems there are just as many opinions as people giving them on-line.
I have a 2003 Toyota Matrix XRS and I want to move the battery from it's present location (under the hood, ahead of the front axle, on the drivers side, up high), to the floor behind the front passenger seat.
What is the proper way to accomplish this?
 - What gage wire is ideal; 0, 00, ?
 - What is the best way to ground it in that location? Am I able to ground the chassis (from the battery) to the OEM seat belt anchor bolt and then ground the engine to the chassis (using a braided ground cable?), or is there a better way.
I want it done right and safe.
Help and thanks
GPz11 (Forum Supporter)
GPz11 (Forum Supporter) Reader
12/6/21 4:13 p.m.
I used 1/0 cable and also grounded the battery to the rear seat belt bolt and added a couple grounds from the engine to the chassis.
My only issue is hum thru my amplifiers / stereo.
I also added a circuit breaker incase of an oopsie.
Oh, I also ran the main power lead in a protective sleeve.
Tom1200
Tom1200 UltraDork
12/6/21 4:23 p.m.
In reply to kevinh333 :
Possibly silly questions. What is the goal of moving the battery? Is this a track car ?
obsolete
obsolete Reader
12/6/21 4:31 p.m.
In my old LeMons car, I used 2 AWG welding cable. Negative grounded through the chassis. I think that's probably about the bare minimum as far as wire size, but it worked great for us. Whatever size you decide to use, I highly recommend the welding cable. It's very flexible and the insulation is super tough with great resistance to heat and abrasion.
kevinh333
kevinh333 Reader
12/6/21 4:35 p.m.
Thanks,
Stupid question; how does one go about grounding an aluminum block and head 2ZZ-GE Matrix engine?
12/6/21 4:37 p.m.
A bolt and a cable?
kevinh333
kevinh333 Reader
12/6/21 4:43 p.m.
In reply to Tom1200 :
Pulled the rear seats and rear cargo pieces out along with other misc. pieces (total weight reduction approximately 200lbs), battery weighs 40-50 lbs and is on the drivers side of the engine bay mounted high and ahead of the front axle, moving it behind the front passenger seat on the floor moves that weight toward the rear of the car and on the passenger side providing a significant and positive changes to weight/balance and center of gravity.
kevinh333
kevinh333 Reader
12/6/21 4:44 p.m.
In reply to obsolete :
WHat about grounding (with an aluminum engine)?
12/6/21 4:51 p.m.
A bolt and a cable?
I am unsure what the issue is.
kevinh333
kevinh333 Reader
12/6/21 5:01 p.m.
In reply to Pete. (l33t FS) :
Another stupid question; would there not be an issue mating steel and aluminum?
Stampie
Stampie MegaDork
12/6/21 5:12 p.m.
Do the math on relocating it and the added weight of the new wire vs. just buying a light weight battery.  I know it's a Challenge car but on our Q45 it made more sense to just run a lawn mower battery instead.
67LS1
67LS1 Reader
12/6/21 5:14 p.m.
If this is a track car, are you allowed to have a battery in the passenger compartment?
If it isn't a track car, is it wise to have a battery in the passenger compartment?
And I agree with Stample, ie, just get a lawn mower battery.
codrus (Forum Supporter)
12/6/21 5:21 p.m.
Usually it needs to go in some kind of battery box.
z31maniac
z31maniac MegaDork
12/6/21 5:32 p.m.
Just throw a lightweight battery in the current location and save yourself the hassle.
12/6/21 5:45 p.m.
All of the other bolts are steel.
Tom1200
Tom1200 UltraDork
12/6/21 8:46 p.m.
Depending on the cars intended use I'd be inclined to simply go with a lightweight battery.
12/6/21 9:08 p.m.
Remote mount battery is kind of a pain in the tail.  Despite using 2/0 cable and being meticulous about connectivity, I measure 30mv of alternator ripple at the battery and 400-700mv of ripple at the battery terminal at the positive terminal underhood that I use to join the new cabling to the car's electrics.
Electronics do not like this.
kevinh333
kevinh333 Reader
12/7/21 9:56 a.m.
Thanks to everyone for all the feedback,
The car is not actually intended for the track other than a rare occasional track day, mostly used for B-road blasting on nice sunny warm MN spring/summer/fall days and nothing more, because of this, stripping the interior to reduce weight was not a problem.
You have convinced me to go with a lighter battery in the OEM location.
Oh, any body interested in purchasing a: battery box, battery post connectors, battery junction box, copper lugs? &#*^%^*#@%&
Any good  lightweight battery recommendations based on my described use of the car above?
Mr. Peabody
Mr. Peabody UltimaDork
12/7/21 10:13 a.m.
I've had some strange things happen after remote mounting batteries, but I wonder if done right is it not better for the battery getting it out of the engine compartment?
In two cars we've owned with factory trunk mounted batteries, the batteries lasted a ridiculous amount of time. So long, in fact, I have no idea when they died. We sold one at 11 years old with the original battery, the other is an 09 and still working
chaparral
chaparral Dork
12/7/21 10:43 a.m.
Bosch Motorsport lithium-ion battery. For best results don't expose it to Minnesota winters, leave it out of the car all winter long. Should last 10-12 years.
chaparral
chaparral Dork
12/7/21 10:43 a.m.
Stampie
Stampie MegaDork
12/7/21 10:53 a.m.
You could just get a cheap lawn battery for $30ish or go really lightweight and pay $100 plus for a lithium battery. If lithium I'd go for a PO4 because of reduced fire risk. Then if you really want to go down a rabbit hole look at the super capacitor battery videos on YouTube.
kevinh333
kevinh333 Reader
12/7/21 11:08 a.m.
Is this the one you are referring to:
Bosch Lithium-Ion Powersport Battery; $54.00 at Pep Boys, primary used for motorcycles
Usually a VENTED battery box.
I researched this a few years ago for a Challenge car, and there technically only 1 box that met both the NHRA and the SCCA rules. It was a vented Moroso box.
And it had to be bolted down a particular way, and required a battery/alternator cutoff switch on the back of the car.
Street car not required, but still a good idea.
jfryjfry
jfryjfry SuperDork
12/7/21 12:47 p.m.
Linky no worky
HWv3Vk6ONrahZAg6PGVPy0c61cLux3JN1dDyaoAiq4qL9jf2l6COCkfbgIDxR2r9
