ditchdigger
ditchdigger Dork
1/15/12 5:02 p.m.
Take the nose piece from one Bosch VW ABA starter, cut the mounting tabs off of it and turn a recess into it
Photobucket
Take the nosepiece from a Marelli Fiat 850 starter and cut away everything after the mounting flange. Machine a lip so it will center itself in the bosch piece.
Photobucket
As best as you can, weld the oil soaked cast aluminum pieces together
Photobucket
and reassemble
Photobucket
Yeah it is ugly, but it works! Strangely the VW starter has the correct gear and rotation direction for a fiat 850. The shaft is even exactly the right size to fit into the support bushing on the fiat nosepeice. It just happened to be on my spare parts shelf since an ABA swap I did back in '05.
Stock 850 starters are getting very hard to find and are pretty weak. This gear reduction unit can spin over a high compression 2 liter with ease and has no issue with my little 843.
Curmudgeon
Curmudgeon SuperDork
1/15/12 5:12 p.m.
Nice work! I bet the starter makes more torque than the motor does.
aeronca65t
aeronca65t Dork
1/15/12 5:12 p.m.
Now ~that's~ grassroots!
Two thumbs up!
Woody
Woody SuperDork
1/15/12 5:13 p.m.
You are awesome.
Trans_Maro
Trans_Maro Dork
1/15/12 5:49 p.m.
Is it safe to let the Germans and Italians get that close again?
Shawn
ditchdigger
ditchdigger Dork
1/15/12 6:29 p.m.
Curmudgeon wrote: Nice work! I bet the starter makes more torque than the motor does.
Lets see. 1.1KW is 1.5hp....Hey! now that is just rude.
Besides I am up over 120hp 100lb/ft now
Last year I did this with a Subaru Legacy starter
Photobucket
But it had the wrong diameter gear on it so I turned the teeth off of it leaving a splined sleeve and then bored out the fiat gear, pressed them together and welded it up. I didn't think it would make it through the first turn of the key but it lasted over a year of hammering on it 20+ times a day and then friday morning it went clunk and whirr.
Photobucket
Trans_Maro wrote: Is it safe to let the Germans and Italians get that close again? Shawn
Italian car loaded with german and japanese parts. This thing here is the original axis of evil.
Toyman01
Toyman01 SuperDork
1/15/12 6:31 p.m.
Nice work!!
carguy123
carguy123 SuperDork
1/15/12 6:38 p.m.
Italian car loaded with german and japanese parts. This thing here is the original AXLE of evil.
thunderzy
thunderzy Reader
1/15/12 9:17 p.m.
Thats foookin awesome.
mad_machine
mad_machine SuperDork
1/15/12 11:53 p.m.
so.. how hard is it to weld greasy aluminum parts together?
curtis73
curtis73 SuperDork
1/16/12 1:29 a.m.
I'm a mix-n-match freak. I have used recycled radio-controlled parts to operate a power mirror.
... but this is grassroots gold, my friend.
I wish we had a :hatsoff: smilie
Knurled
Knurled Dork
1/16/12 5:20 a.m.
You'll never get your core charge back now.
I wonder if you could hack a Mazda rotary starter to work. They are also transmission-side starters, and the nonturbo manual trans units come in 8, 9, and 11 tooth models, or something like that. And they're quite strong. The 11-tooth models are gear reduction to boot.
Here's the part that always makes me woozy when I think about it. All three starters use the same flywheel size/tooth count, the same transmission mounting point, and the same case dimensions, and are in fact 100% interchangeable. I am not quite sure how that even works. I had an 11-tooth (FC) starter and a dead 8-tooth (SA) starter, looked at 'em carefully, measured, said no way in hell this would work. People on The Internet said it'd work, but I had micrometers and stuff, it couldn't possibly work!
So, just to show them, I bolted it in. Naturally, it worked just fine, aside from my SA sounding like an FC when I cranked it, which is just wrong. SAs should have a geary grindy crank, not a turbine spooling up crank!
erohslc
erohslc HalfDork
1/16/12 9:34 a.m.
Hey ditchdigger, maybe you just started a new cottage industry ... ;)
erohslc
erohslc HalfDork
1/16/12 9:35 a.m.
mad_machine wrote: so.. how hard is it to weld greasy aluminum parts together?
Just use greasy welding rods ....
J308
J308 Reader
1/16/12 9:42 a.m.
In reply to Knurled: Wow. What the berkeley.
ditchdigger
ditchdigger Dork
1/16/12 10:40 a.m.
In reply to Knurled: The mind reels.
This makes me wonder just how much gear mesh is needed and actually set. It also makes me wonder if the 11 tooth denso gear would fit when the 9 tooth didn't.
I5EDVdwpZ1vTkIkrbKkHzSSm6XiAwN0hT2IyTCBrBOSMddpwZXxonBVCRqICD35Y
