Gearhead_42
Gearhead_42 Dork
9/28/13 8:42 a.m.
Foremost style drill motor with flex shaft, or long snout electric die grinder?
Discuss.
Derick Freese
Derick Freese UltraDork
9/28/13 8:52 a.m.
I use a Dremel with a flex shaft and a variable foot pedal speed control. It limits me in the bits I can use, but there are plenty available these days. The right carbide burrs will cut through anything, even with my run of the mill Dremel.
Derick Freese
9/28/13 8:53 a.m.
By the way, my next project will use a larger spare motor with a finer foot pedal control, and I'll use a flex shaft capable of 1/4" tools.
impulsive
impulsive Reader
9/28/13 9:55 a.m.
I use a variable speed Dremel w/flex shaft for small stuff & a 1/4" Makita ge0600 with a foot pedal for serious material removal.
oldeskewltoy
oldeskewltoy Dork
9/28/13 11:44 a.m.
Dremel w/flex and 56k rpm 1/8" micro air die grinder
I use mostly Foredom for my supplies - http://www.foredom.net/
I also have looked into the equipment available here as well... MUCH finer equipment much more cost.... - http://www.ccspecialtytool.com/
nLmi51o0SS3bzJ1YZXSeadqY0uFLQ2ANvl2onbLcGcYQuNcSli92xxSeiHW6oWP9
