daeman
daeman Dork
3/15/19 5:12 a.m.
Any updates?
I'm considering trying this with an 03 Forester, the leak is minimal and I really don't feel like doing head gaskets on a low dollar daily driver.
Mr. Lee
Mr. Lee PowerDork
5/9/19 4:24 p.m.
Our sentra is still kicking along. No complaints here.
java230
java230 UltraDork
5/9/19 4:27 p.m.
Funny this popped up, I just poured a bottle of the blue juice into my truck yesterday.
I emptied the system and filled with water. Online instructions said wasn't needed, bottle said use water.....
I did not pull Tstat (its built into the neck), will probably give it a few days and drain and refill the system.
java230
java230 UltraDork
5/15/19 12:39 p.m.
Well, truck started to overheat again (loosing coolant is what it was previously doing.... ) Popped the hood, coolant was really low. Blue devil dries white..... There is white spray all over..... UGH. There wasn't coolant spray all over there before....
BlindPirate
BlindPirate Reader
5/15/19 7:37 p.m.
I bought what should have been a nice used John Deere garden tractor, 20 hp water cooled engine. It has actually been one nightmare after another. Last spring had to search the country for a replacement cylinder head. Just a couple weeks ago it cracked another head. It had so much water in the cylinder it just wouldn't start. After a few days of drying out and nothing to lose I got it going and dumped a bottle of the magic blue stuff in it. It took about 20 minutes for it to quit smoking. So far so good
Robbie
Robbie UltimaDork
5/15/19 9:19 p.m.
In reply to java230 :
I don't get it. Your water pump is busted? Or am I not seeing the white spray correctly.
java230
java230 UltraDork
5/15/19 10:07 p.m.
In reply to Robbie :
Nope not water pump. Appears to be the crank position sensor. Not sure why that sprouted a leak.... Hopefully it'll be fixed tomorrow. It's an oring seal.
java230
java230 UltraDork
5/16/19 4:08 p.m.
Well I'll have to eat my shorts. Sure looks like its the Waterpump. Damn it!
Robbie
Robbie UltimaDork
5/16/19 9:35 p.m.
Doh! An oring would've been Soo much easier!!
java230
java230 UltraDork
5/16/19 10:44 p.m.
Changed the Oring anyway, it must have been leaking a little oil into the white powdery stuff to make it look like a wet spot.
Waterpump ordered....
Furious_E
Furious_E UltraDork
5/17/19 12:02 p.m.
Ok, so my RX7 has a pinhole leak in the radiator and I need it functional for the Carlisle Import Show tomorrow. I attempted a fix with JB Weld, but it still seems to be weeping a bit from an area I cannot easily access. Is this stuff worth a shot? Blue Devil Radiator and Block Sealer
I just need a quick fix for now that gets me up and running for tomorrow, but I actually give several E36 M3s about this car and motor, so I don't want to crap up the cooling system with gunk that is going to cause problems or be a PITA to flush out later. This will just be a temporary fix until I can order a new radiator, since this one has several other repairs due to the poor design of my old upper mounts (now fixed.)
I'm also intrigued by Duster's nutmeg suggestion. Do I just steal a thing of it out of the spice cabinet and dump it in the radiator? Anyone else had success with this?
Professor_Brap
Professor_Brap Dork
5/17/19 12:10 p.m.
In reply to Furious_E :
I have used a EGG a few times with great sucess.
rslifkin
rslifkin UltraDork
5/17/19 12:16 p.m.
Personally, I wouldn't try a fix in a bottle if you give a E36 M3 about anything in the system.  You can greatly reduce a leak by temporarily running the system at 0 pressure.  Just try to keep temps under 200* and don't beat on it.  And keep the revs down a bit (to avoid water pump cavitation).
Furious_E
Furious_E UltraDork
5/17/19 2:40 p.m.
In reply to rslifkin :
That's kind of my inclination as well, but given all the positive reviews in this thread I figured it might be worth a shot. Certainly tempting. If I'm taking this car I don't want to have to worry about babying it the whole time, since my primary interest there is running the auto x. Further complicating matters, I have a new and untested e-fan and shroud setup, so I have no idea what to expect for coolant temps while idling in line.
rslifkin
rslifkin UltraDork
5/17/19 2:52 p.m.
No way to just pick up a radiator locally, even if it's a cheap one?
Furious_E
Furious_E UltraDork
5/17/19 3:06 p.m.
Problem is it's LS1 swapped, so not exactly an off-the-shelf application. Radiator mounts, coolant hoses, fan shroud, ect. are all setup around the Speedway radiator that's in it now. I'm sure I probably could find something locally that could be made to work, but likely not without significant reengineering of one or more ancillary systems.
Furious_E
Furious_E UltraDork
5/17/19 5:14 p.m.
Ok, so taking another look I'm pretty sure this can be fixed with JB Weld. Gonna give that a try.
wvumtnbkr
wvumtnbkr UberDork
5/17/19 9:23 p.m.
If it is in 1 of the fins, and not an end tank or anything, you can just crimp the fin before and afyer the hole.
Dusterbd13-michael
Dusterbd13-michael MegaDork
5/17/19 10:11 p.m.
Nutmeg from the kitchen is what i have used more than once for pinholes. Worked every time ive tried it.
7JQDMZPYF9ZK997HigDW93hvGQnviSI6ALvROJYLwUmoCnrLGQDgdWTfdIBem1mz
