Is there some rule regarding the orientation of the sleeve bolts on bolt-in roll cages?
Mmm.... not that I am aware of. Common sense would dictate that the bolt go through in such a way that both the head and the threaded part would not be where your head would be likely to hit it, i.e. at 90 degrees to the most likely point of impact. Or at least have the head of the bolt on the side your noggin is most likely to get close to, the threaded part would be pointing away.
Woody wrote: Is there some rule regarding the orientation of the sleeve bolts on bolt-in roll cages?
Gay, straight, or anything in between. All sleeve bolts are welcome!
Bryce
