Fitzauto
Fitzauto HalfDork
2/18/16 12:20 p.m.
Exactly as the title says. Trying to remove the brake caliper so I can change my wheel bearings but that sucker is on there. Im thinking hammer?
1988RedT2
1988RedT2 PowerDork
2/18/16 12:22 p.m.
More details please? What car? Age? Rust much?
outasite
outasite Reader
2/18/16 12:26 p.m.
single or dual piston??
Fitzauto
Fitzauto HalfDork
2/18/16 12:27 p.m.
Single piston. The pads are clamped down fairly tight on the rotor.
1988RedT2
1988RedT2 PowerDork
2/18/16 12:29 p.m.
Assuming you've removed the proper caliper mounting bolts, I've used a short piece of 2x4 struck with a heavy hammer to persuade a caliper to come off. Be careful not to damage the brake hose if you don't intend to replace it.
edizzle89
edizzle89 HalfDork
2/18/16 12:33 p.m.
maybe open the bleeder and see if you can pry it off then?
Fitzauto
Fitzauto HalfDork
2/18/16 12:36 p.m.
In reply to 1988RedT2:
This is pretty much what I was thinking. The caliper/mounting bracket are just hanging on the rotor now.
Furious_E
Furious_E HalfDork
2/18/16 12:37 p.m.
1988RedT2 wrote: Assuming you've removed the proper caliper mounting bolts, I've used a short piece of 2x4 struck with a heavy hammer to persuade a caliper to come off. Be careful not to damage the brake hose if you don't intend to replace it.
Done this, it works.
"When all else fails, brute force prevails" - words to live by
BrokenYugo
BrokenYugo UltimaDork
2/18/16 12:43 p.m.
Before I pull any bolts I like to retract the caliper piston with a prybar.
ncjay
ncjay Dork
2/18/16 12:53 p.m.
A C clamp large enough to compress the piston back in the bore is useful here. Thinking there shouldn't be all that much pressure on the pads at this point to begin with.
chiodos
chiodos Dork
2/18/16 12:54 p.m.
sometimes theres a lip created by pads not touching the furthest outside bit that holds it on sometimes.. I agree with the prybar method just compress the piston(s) just enough to release..
or get a bigger hammer haha
novaderrik
novaderrik UltimaDork
2/18/16 12:55 p.m.
use a large c clamp or channel lock or whatever you can get around the caliper to push the piston back into the body. those big vise grips that look like fingers (i forget what the proper term is) can also be used if it's all you've got.
HappyAndy
HappyAndy UberDork
2/18/16 1:03 p.m.
Is this a rear caliper with integrated P brake mechanism? Some have not so obvious release mechanisms.
Kia_Racer
Kia_Racer SuperDork
2/18/16 1:21 p.m.
HappyAndy wrote: Is this a rear caliper with integrated P brake mechanism? Some have not so obvious release mechanisms.
My thought exactly.
Desmond
Desmond Reader
2/18/16 2:02 p.m.
Yeah like the Miatas have a key that you have to put in the caliper and turn to back it out. If you try to force it, you will probably damage it. Check a DIY online to see if maybe your caliper has something like this.
glueguy
glueguy HalfDork
2/18/16 2:27 p.m.
While a bfhammer sounds fun, it has to be the pads causing this. Retract the piston as has been mentioned.
daeman
daeman HalfDork
2/18/16 2:46 p.m.
Assuming its a 2 peice calliper, Undo the bolts for the slides, the piston section of the calliper should then come off pretty easy. After that, pop the pads out and then remove the calliper frame.
AngryCorvair
AngryCorvair UltimaDork
2/18/16 4:03 p.m.
ALWAYS open the bleeder screw before pushing the pistons in. Dirty fluid goes out the bleeder, then top off MC with new fluid.
The Hoff
The Hoff UltraDork
2/18/16 4:07 p.m.
Or the parking brake is still on?
Fitzauto
Fitzauto HalfDork
2/18/16 5:27 p.m.
Got it off. Tapped it abit with the hammer and it slid right off. Turbs out some rust was holding it on.
qNQsp3lVD5bMIrJL7kCNFnsVTXVFeCT6r4xKDcvf0D61bK1otQjY1EQ5pt2ViFcl
