JohnInKansas
JohnInKansas HalfDork
11/5/12 1:55 p.m.
'91 Legacy wagon, automatic, AWD.
I've got a dolly, but being AWD, I'm not sure how to go about towing with the fronts off the ground.
Can I just disconnect/remove the rear driveshaft?
m4ff3w
m4ff3w UltraDork
11/5/12 1:56 p.m.
JohnInKansas wrote: Can I just disconnect/remove the rear driveshaft?
That should be the correct method, yes.
sachilles
sachilles SuperDork
11/5/12 2:27 p.m.
Should be able to find a fuse in the underhood fuse box labeled FWD, intended just for this purpose.
JohnInKansas
11/5/12 2:29 p.m.
In reply to sachilles:
And I just pull the fuse?
sachilles
sachilles SuperDork
11/5/12 2:32 p.m.
Yup. Verify in the owners manual. It was intended for towing the car when a flat bed wasn't available. Only on automatic cars, with certain transmissions. That is why I'd verify.
sachilles
sachilles SuperDork
11/5/12 2:38 p.m.
Correction, you have to put a fuse in. How far do you plan to tow? Disconnectiong the shaft is a wise thing if you are going a great distance.
JohnInKansas
11/5/12 2:45 p.m.
~120 miles.
N Sperlo
N Sperlo PowerDork
11/5/12 2:47 p.m.
Disconnect the shaft. It's always the proper way.
motomoron
motomoron Dork
11/5/12 3:19 p.m.
Woody
Woody MegaDork
11/5/12 3:27 p.m.
motomoron wrote: "You're bending the shaft!! Stop bending the shaft!"
Ha! I remember that!
Tom Suddard
Tom Suddard Intern
11/5/12 6:05 p.m.
sachilles wrote: Should be able to find a fuse in the underhood fuse box labeled FWD, intended just for this purpose.
Wait, really? I thought that was a joke.
Learn me?
N Sperlo
N Sperlo PowerDork
11/5/12 6:35 p.m.
Wait, really? I thought that was a joke. Learn me?
Disconnect the shaft. I've had E36 M3ty transmissions throw bolts when pushed. Its a good thing I was scrapping that transmission.
ahaile930
ahaile930
11/5/12 7:50 p.m.
WOW can he just pull the car the way these big motor homes pull a small car behind for miles n miles?
novaderrik
novaderrik UltraDork
11/5/12 9:13 p.m.
sachilles wrote: Correction, you have to put a fuse in. How far do you plan to tow? Disconnectiong the shaft is a wise thing if you are going a great distance.
so you need to have a battery in the car and have this fuse installed if you want to tow it with a tow dolly?
this is why i prefer my dumb stupid domestic cars... they make more sense..
Tom Suddard
Tom Suddard Intern
11/5/12 9:29 p.m.
That's genius, a regular domestic car simply couldn't be towed at all. I'm assuming the fuse energizes the transmission fluid pump to keep everything lubricated?
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
11/6/12 6:07 a.m.
Some of the AllTracs had a "tow mode" where they somehow just became FWD cars... It's not recommended you DRIVE them like that, but that's how you tow them.
sachilles
sachilles SuperDork
11/6/12 8:08 a.m.
In reply to Tom Suddard: just engergizes the pucks in the center diff allowing it to be open.
verGQuyRYTwp2YFamNaEDpzZqwY7gsPOouxsQter3NyTKQtwTm3QKr8R6t4kD7Hw
