Indy - Guy
Indy - Guy UltimaDork
3/11/25 12:21 p.m.
Thanks so much everyone for your feedback and creative contributions.
Tom: heard, We will not do the original concept.
Trying to blend some of the great suggestions into something achievable for minimal budget hit/ effort and maximum effect.
How about this?
Somebeach (Forum Supporter)
Somebeach (Forum Supporter) Dork
3/11/25 12:30 p.m.
Unfortunately I won't be coming to the challenge, but I am excited to see how this thing does.
I wonder how it would look with the Swedish flag with the cross part right in front of the rear tire , running down the side kind of like like the Supra from fast and the furious had the arms on the side running down.
STM317
STM317 PowerDork
3/11/25 12:50 p.m.
What about this but yellow separated by the volvo blue?
Quick and dirty:
That's a little far forward for me, and leaves the back of the car looking pretty barren by contrast. I think I'd like it better with the stripe moved behind the front wheel opening. Start it down around the rocker, and then go over the hood like above.
STM317
STM317 PowerDork
3/11/25 1:10 p.m.
Adjust position, width, angles, etc to suit your taste
STM317
STM317 PowerDork
3/11/25 1:29 p.m.
STM317
STM317 PowerDork
3/11/25 1:47 p.m.
Trying to follow some body lines
Dusterbd13
Dusterbd13 MegaDork
3/11/25 2:08 p.m.
Move the stripe forward to center it in the wheel well and then do a longitudinal stripe offset down the driver side of the hood so when viewed from above it looks like the Swedish flag. That will allow the sponsorship decals to run along the bottom of the door for all the challenge required logos underneath the meatball kind of along the rocker. It also gives it an appealing look from all directions with the stripe going up from the air dam over the hood over the cowl over the roof over the trunk it'll photograph well from the air and from all angles I also want to edit to add that you can get blue epoxy primer to do the entire car with a Fresh coat of epoxy since you plan to do that anyway. The way that I've done that in the past is you buy a white epoxy primer and the body supply shop tinted blue for you or whatever color you want
maschinenbau
maschinenbau PowerDork
3/11/25 2:57 p.m.
In reply to Dusterbd13 :
Looking like a BRE Datsun suddenly. Not a bad idea for a Challenge car. Might even help you win :)
Indy - Guy
3/11/25 3:07 p.m.
In reply to maschinenbau :
Ha!
We were just discussing Datsaniti last night, and the similarities of our car two yours:
  • both basically chassis swapped: modern running gear under vintage tin
  • Datsaniti's first Challenge run was in unfinished gray primer (ours will be too)
  • Datsaniti was further developed thru the year (with power adder)
  • Datsaniti got a new paint Livery and returned the next year to win the Whole thing!
So, we're looking to duplicate your fine example/performance wink
Dusterbd13
Dusterbd13 MegaDork
3/11/25 3:15 p.m.
Think more 90s corvette gs stripes
maschinenbau
3/11/25 3:31 p.m.
In reply to Indy - Guy :
While I'll be cheering you on, remember first step is beating a humble Camry daily driver with flaking clear coat laugh
I might actually have some leftover Rice Rod turquoise paint. Looks very similar to that patch on your door. Not sure if that's useful in the parking lot or not. Could brush it on between masked off lines.
VolvoHeretic
VolvoHeretic SuperDork
3/11/25 7:12 p.m.
If you bought a cheap self leveling laser that also locks into place and aimed down onto the car from the ceiling, you could draw an off-center Swedish cross onto the top of the car and then by off setting the second side of the line, mask it off and paint. Imagine the car below in Swedish blue with a nice yellow cross flowing over the top and down the sides of the car. smiley Kind of like this:
garaithon
garaithon Reader
3/11/25 9:16 p.m.
In reply to STM317 :
I'm liking this, highlights the body lines nicely! Leaves room for all the decals and sponsors as well!
garaithon
garaithon Reader
3/11/25 9:17 p.m.
This right here...
Mugglesworth
Mugglesworth New Reader
3/11/25 10:51 p.m.
STM317
STM317 PowerDork
3/12/25 6:04 a.m.
What are the requirements for sponsor/GRM sticker placement?
Indy - Guy
3/12/25 7:15 a.m.
Mugglesworth said:
I like that a lot.  Very creative and it hints at both the body lines and gives the impression of speed while sitting still.
Indy - Guy
3/12/25 7:17 a.m.
garaithon said:
This right here...
A bit more difficult to implement with varying vinyl widths and following body line curves.
The beauty ( from an implementation standpoint) was it could be done with straight rolls of vinyl.  The only curve required was the round sun.
Indy - Guy
3/12/25 7:26 a.m.
In reply to garaithon :
We talked about painting the trunk gray primer.
Legit question: Are we painting the turquoise portion gray too or not?
STM317
STM317 PowerDork
3/12/25 7:51 a.m.
Playing with body lines a bit more. I'd run the stripe over the rear of the roof to join the other side kind of Starsky and Hutch style
maschinenbau
3/12/25 9:22 a.m.
garaithon said:
This right here...
100% this one right here
STM317
STM317 PowerDork
3/12/25 10:17 a.m.
Combining some of the preferred concepts:
NOHOME MegaDork
3/12/25 10:19 a.m.
I posted this on the other thread, but this symbol would fit perfectly where the door-meatball resides
NOHOME MegaDork
3/12/25 10:31 a.m.
Robbie (Forum Supporter)
3/12/25 11:31 a.m.
I think you should paint one spoke of each wheel with a Swedish flag
5RNZ1EnIzLSgPnlxdCn6jN0dRusLTgJRh2h02qx1t90SIkHxUzR6RieFTMiHOirM
