7/5/15 1:46 p.m.
Anything I need to know? If I put it on a regular 12v/2a trickle am I OK? Thanks.
Rob_Mopar
Rob_Mopar UltraDork
7/5/15 2:44 p.m.
Duke, is it fully discharged? If so you need either a charger with an AGM setting, or you might need to put another battery in parallel so your regular trickle will see it.
Kenny_McCormic
Kenny_McCormic PowerDork
7/5/15 2:49 p.m.
Yup, just fine. IIRC they don't like to be fast charged even worse than other lead acid batteries though. 2 amps won't be an issue.
7/5/15 2:49 p.m.
I don't think it's fully discharged. I have the trickle charger on and it is showing 3a or so charging rate.
Rob_Mopar
Rob_Mopar UltraDork
7/5/15 3:42 p.m.
Should be fine.
7/5/15 4:14 p.m.
Cool, thanks, gang.
j8jzCDealaA0ONR4Q09jCHWKKrq20rBH0BGR04sDh8kQDTByYzg08SJQW3KU40fX
