Scott Lear
Scott Lear
8/19/08 4:39 p.m.
A few people told us that we shouldn't worry too much after we lost our radiator fan at Roebling Road, but the insanely hot temperatures and too-slow lap speeds during yellow flag conditions at HyperFest led us to believe otherwise. The easiest and least horsepower-sapping solution would be a repla…
purplepeopleeater
purplepeopleeater Reader
8/24/08 3:31 p.m.
No relay?
Scott Lear
Scott Lear
8/25/08 10:53 a.m.
Nope, the switch we used has a sufficiently high amperage rating. If it becomes an issue, we'll put a relay in there.
scotaku
scotaku New Reader
8/26/08 9:04 p.m.
It looks like you've wired it to run only from the switch, Scott. Are you sure you don't want a thermoswitch to get the fan moving just as the clutched fan would have and use the toggle as an on-demand fan?
Scott Lear
Scott Lear
8/27/08 8:28 a.m.
In this case, I think the simplicity of a single switch will be good. That, and I'm quite the novice when it comes to electrical systems, there's fewer things I could have screwed up this way.
jHszMauXFTQ7hV2QA89r3WRAWO15i9tHw7zsXa3W7WmpmeBlhmaC7KVAdws3iQ6N
