Gearheadotaku
Gearheadotaku Dork
10/7/11 7:44 p.m.
Before I buy parts I don't need, Best way to determine bad clutch master vs. bad slave? Always seems to be a little air left when bled, and pedal goes limp after sitting for a while.
HappyAndy
HappyAndy HalfDork
10/7/11 8:18 p.m.
With that description it could be either or. Have you tried to reverse bleeding it? In other words, pushing fluid up from the slave through the master to the resevior.
What kind of slave cyl does it have? External or internal, if its external its probably cheap and easy to replace.
Ranger50
Ranger50 Dork
10/7/11 8:27 p.m.
Which have you changed and with who's parts?
Typically, I have found that a bad slave leaves you with a soft spongy pedal that doesn't allow shifting. A bad master is a fricking brick to push.
egnorant
egnorant Dork
10/7/11 9:30 p.m.
I always diagnose wrong and replace both, except on the Ranger (slave is the throwout bearing and the transmission must be removed)..then I just cry because it turned out to be the hose.
Bruce
Chas_H
Chas_H New Reader
10/7/11 10:41 p.m.
A limp pedal is usually a bad slave cylinder. The master will leak fluid into the car if it's bad, but will continue to work until it runs out fluid. Check the slave for sirgs of leakage.
Gearheadotaku
Gearheadotaku Dork
10/7/11 10:50 p.m.
Haven't found any leaks, and it's an external slave. It's easy to get to, looks like I'm starting there. Thanks for the tips everyone.
cwh
cwh SuperDork
10/8/11 10:25 a.m.
IIRC, rebuild kits for both are cheap. Might as well do both at the same time.
Gearheadotaku
Gearheadotaku Dork
10/8/11 6:23 p.m.
Of course no one in town has one, have to wait for Monday
wE3GaJKAgGzL1olbv7v17fYNCereL51WJNrUmHRPmlawqcfEDPdHmqlOndXF2qYo
