markwemple
markwemple UltraDork
12/17/16 11:19 a.m.
Driving home, my 03 7.3 just up and quit at highway speeds. Safely pulled over and got a tow. It was showing about 1/8th of a tank. I added 10 gallons. I've been cranking it over but no start. Ideas?
rslifkin
rslifkin Dork
12/17/16 11:27 a.m.
Have you checked the oil level? Low oil will starve the HPOP and lead to no fuel being injected.
When you crank, do you get any smell / smoke out of the exhaust?
Huckleberry
Huckleberry MegaDork
12/17/16 11:34 a.m.
RIP
PMRacing
PMRacing SuperDork
12/17/16 12:00 p.m.
Crank angle sensor. 10 min fix. It's on the front of the engine and are known to go bad and stall the engine suddenly .
Vigo PowerDork
12/17/16 12:51 p.m.
On many cars with a tach, the tach will bounce or go to 2-300 rpm during cranking. If it did before and now stays at 0, that's anecdotal corroboration of the crank sensor idea. Of course, a scan tool would be far more precise if you know someone who has one or are ready to pick one up. A cheap OBD2 bluetooth adapter and a phone app are usually cheaper and far more capable than even the cheapest code readers these days.
markwemple
12/17/16 1:35 p.m.
PMRacing wrote: Crank angle sensor. 10 min fix. It's on the front of the engine and are known to go bad and stall the engine suddenly .
Damn. Famous on these. Can't believe I forgot!
SEADave
SEADave HalfDork
12/17/16 1:59 p.m.
Died while running sure sounds like a CPS on a 7.3 PSD. Remember there was a recall on these and an improved part#, etc so you may be able to get it free from the dealer.
I think the general consesus is to go Ford OEM on these.
markwemple
12/17/16 2:21 p.m.
Oil level is at the top. Not much smoke out the back so it may be fuel but I'm going to ford for a cps just in case. Wish they had better hours Already closed.
markwemple
12/17/16 2:35 p.m.
Just remembered to check tach movement when I turned the key Nothing. So probably cps
93gsxturbo
93gsxturbo Dork
12/18/16 10:16 a.m.
02 and 03 7.3s do not bounce the tach during cranking. 99-01 do.
Get an actual scanner and see what you have going on. Or punt and replace the CPS and see what you get.
markwemple
12/18/16 10:40 a.m.
I'm going to try the cps because the next obvious issue is fuel pump?
Ranger50
Ranger50 UltimaDork
12/18/16 12:29 p.m.
markwemple wrote: I'm going to try the cps because the next obvious issue is fuel pump?
Normally I saw ICP sensor issues with a low hpop oil reading which can cause a no run no more problem. That's because without enough oil pressure the injectors won't fire and the computer will shut down.
markwemple
12/18/16 5:25 p.m.
Should be no hpop issues. It was running fine.
markwemple
12/18/16 5:28 p.m.
Also no SES light
APEowner
APEowner New Reader
12/19/16 2:56 p.m.
If you're going to fire the parts canon at it the the CPS is the part to throw at it first. After that I'd get a good scan tool on it and see what's really up because it could be anything.
Cotton
Cotton UberDork
12/19/16 3:38 p.m.
When mine did that it turned out to be the CPS. Cheap and easy fix.
markwemple
12/23/16 12:02 p.m.
Replaced CPS. kicking but no start. WTS light is coming on and going off like normal.
BoxheadTim
BoxheadTim MegaDork
12/23/16 12:12 p.m.
Pull the codes.
markwemple
12/23/16 12:28 p.m.
Don't have a way
SEADave
SEADave HalfDork
12/23/16 1:06 p.m.
Go on one of the Powerstroke boards and see if someone local to you has autoenginuity and can scan your truck. I'd do it if you were local.
markwemple
12/23/16 1:55 p.m.
A regular scanner won't work, right?
rslifkin
rslifkin Dork
12/23/16 1:57 p.m.
markwemple wrote: A regular scanner won't work, right?
It should be able to read a standard OBDII code, but something that speaks Ford will give you more info (especially if you don't have a CEL and probably no OBDII codes).
Brokeback
Brokeback Reader
12/23/16 2:15 p.m.
Maybe the CPS died and at the same time it got low enough on fuel that it got air in the system? Weird timing though. Have you run it below 1/8 tank before?
93gsxturbo
93gsxturbo Dork
12/23/16 2:21 p.m.
Powerstrokes of that vintage don't really get air in the system per se as the HEUI injectors are their own pumps. As long as you are getting low pressure fuel to the rails in the heads, its bled enough to start. May rattle and run rough for a minute but doesnt need to be bled like a conventional diesel with a remote high pressure pump.
If you are just trying to diagnose it, open up the fuel filter in the V of the engine and make sure you have fuel there, you should also hear the low pressure pump run with the key on.
You can also remove a plug on the top of the high pressure oil pump and make sure your HPOP is reasonably full of oil, no oil in the HPOP reservoir is no bueno.
markwemple
12/23/16 2:21 p.m.
In checking things, I knew my GPR was acting up. Discovered that the pole that delivers 12v was almost broken off and is now broken off. Could this be the problem?
NGiJjqH1vmCuCnT6U0HyCnwwjIZ0jIh595SntaSsCWztuTIsb5BFhNo5iWLKO5c8
