freetors
freetors Reader
10/27/19 6:27 a.m.
EricsRacing said:
I made this with bearings under the stand I made. Turns easy. I did not want to spend $ on turnplates. Plastic bags just seemed funny
I've never heard had much luck trying to do alignments in the dark. It's too hard to read the tape measures
NormPeterson
NormPeterson New Reader
10/27/19 10:04 a.m.
In reply to iceracer :
Once you know how far out of level your "setup area" is, you can always correct camber measurements and caster calculations to suit.  If it's less than about 1/8" out of level laterally across a 60" track width, you're about to get below the resolution of commonly available angle finders and it may not even be worth the trouble to compensate the measured camber angles for.
Norm
UJgkXB9g7kTqdeQeQ4kIZmAbnVQTtoTCjEABUBKAg5TRMy3BSB2hZeXMudW2aXtM
