Coldsnap
Coldsnap Reader
8/13/13 6:38 a.m.
Just wondering if anyone knoes if Nissan Sentra 2004-2005 automatics have fly wheels or will that be just on the manual version? Thanks in advance.
Toyman01
Toyman01 PowerDork
8/13/13 6:56 a.m.
I won't say definitely not because I've seen some pretty strange things, but no. They have a flex plate and a torque converter.
Coldsnap
Coldsnap Reader
8/13/13 7:02 a.m.
That's what I thought too, asked the mechanic and he said no it's a flywheel. I got an estimate to fix my starter which was $1,100 because the flywheel needs to be replaced. Sounds to me though that if the starter chewed up anything it's the flex plate, which is cheaper. Also there's always the option of tuning my engine to another timing so the worn out contact between the starter and flex plate are at another location.
Knurled
Knurled UberDork
8/13/13 7:21 a.m.
Your mechanic is an idiot. I'll be blunt, here.
iceracer
iceracer UberDork
8/13/13 8:45 a.m.
Some people call a flex plate a flywheel .
Saw that some where.
Knurled
Knurled UberDork
8/13/13 12:06 p.m.
That's semantics and I'll let that slide.
The idiot part is this:
"Also there's always the option of tuning my engine to another timing so the worn out contact between the starter and flex plate are at another location."
I'm trying to fathom exactly what this means. The bad spot in the ring gear will always be there. Did he mean take it off and reclock it (will require minimum of drilling, possibly plug-welding) which will be at least as much as replacing the component, and will accomplish absolutely nothing, or what exactly?
Run_Away
Run_Away Reader
8/13/13 12:26 p.m.
Some cars have the starter ring gear on the torque converter, and there is a flex plate on the crankshaft. When the ring gear is on the flex plate, I've heard it called both a flywheel and flex plate.
06HHR
06HHR Reader
8/13/13 3:03 p.m.
Easy way to find out Engine parts diagram Sometimes the google is your friend..
Knurled
Knurled UberDork
8/13/13 4:43 p.m.
What's nice is a lot of cars out there with manual transmissions use flexplates and cassette clutch assemblies. That way there's only one engine for the assembly line.
iceracer
iceracer UberDork
8/13/13 4:48 p.m.
Used to be you could just replace the ring gear. done it many times. Maybe that is just on flywheels.
sZQWmLH8MwwJ0B2UVKDT0qfJCD9BadErWa0F1N9VQlJpshVnVzpvJgJuoGNZVl6O
