Tom1200
Tom1200 SuperDork
1/26/21 10:38 a.m.
Currently I take the Datsun to be corner weighted and on the F500 I use bathroom scales as the car is only 640lbs.
Without scales I tend to do the corner weights on the Datsun about every 5 years or so (not good) and I would like something more accurate for the F500.
I've seen Proform for as little as $700 and for what I need Longacre or Intercomp are around $1100.
So do we have a preferred brand?
wvumtnbkr
wvumtnbkr PowerDork
1/26/21 11:27 a.m.
I just bought the preform wireless ones.  Right around 850$ shipped.
They are very nice and well made.
Only had them for a few weeks, but I am impressed.
frenchyd
frenchyd UltimaDork
1/26/21 11:36 a.m.
In reply to Tom1200 :
I use bathroom scales on much heavier cars. 10-1 levers make the math real simple and increase capacity enough to handle most race cars.
Yes have everything flat and level is very important. But even a concrete garage floor can simply be leveled. Flood the floor with water.  Let it dry off and measure the water depth when the high spots dry out. ( squirt a drop or two of soap in each puddle). I use flooring tile and plastic shims. Cutting a square of plastic from various sheet thickness.  Then I mark where the spots are and bag up the tiles/ plastic shims. Mark each bag Spot A B C D.  The scales slide easily on top of the plastic so I know nothing is binding.
     On my Black Jack special with knock offs I had a set with the center cut out.  Then a center stand with a 5-1 torque wrench.  That was my quick and dirty way of checking the car if I raised or lowered the ride height.  Torsion bar suspension. ( some tracks require higher ride heights to keep from bottoming )  in a few minutes I could confirm the right corner weights.
Tom1200
Tom1200 SuperDork
1/26/21 12:13 p.m.
In reply to frenchyd :
My garage floor is actually level. No idea how this happened but it is.
APEowner
APEowner Dork
1/26/21 1:52 p.m.
I've use both intercomp and longacre.  I can't say as I have a preference.  My own are Intercomp.  They work and hold calibration.
Patientzero
Patientzero HalfDork
1/26/21 3:04 p.m.
Another vote for the Proform Wireless scales.  Mine have been great.
L5wolvesf
L5wolvesf HalfDork
1/27/21 2:10 p.m.
Could you explain further on this? Perhaps on another thread unless Tom doesn't mind. It sounds like something I could afford if I knew the details. Thank you
collinskl1
collinskl1 Reader
1/27/21 2:12 p.m.
Ruggles Scales is another term for this method
Tom1200
Tom1200 SuperDork
1/27/21 3:16 p.m.
In reply to L5wolvesf :
Don't mind at all. The last time I looked at Ruggles Scales I think they were half the price of the standard ones.
My Datsun sees very little change so I normally just take it to a guy who sets up race cars whenever I make a big change.
The only reason I'm considering them now is because we have 3 cars that can be adjusted so it's starting to make sense. Granted the F500 is light enough I've been making do with bathroom scales.
jiLa8BlcE60Iyl8SVGGta7w9WFkOBOErEir25RzmMqRs3UcsXPbaJGm2ZvA9rVkc
