eastsideTim
eastsideTim UltimaDork
7/29/23 2:43 p.m.
My project Mercedes has a two piece drive shaft that I am replacing the giubos and the center support in.  I have it out of the car and apart, and noticed while there is no slop in the u-joint, it can be moved a few degrees in either direction easily, then it hits a friction point that if I move it past, it gets easier to move, but not as easy as those first few degrees.  Is this a sign it is worn and needs replacement, or is this pretty normal?  The car has independent rear suspension, so the range of movement for the joint is pretty small, and I am guessing that is where the easier movement is.
7/29/23 3:21 p.m.
Indexing.  Technically yes, it should be replaced, if it isn't simply gummed grease.  If you can exercise it a bunch and smooth it out, it was just grease.
eastsideTim
7/29/23 3:40 p.m.
In reply to Pete. (l33t FS) :
Moved it a few hundred times past the friction point on both axes, and they are still there.  Guessing it is time to haul it to a driveshaft shop?
Sonic
Sonic UberDork
7/29/23 4:16 p.m.
If you have it out, now is the time.
wae
wae PowerDork
7/29/23 4:57 p.m.
I mean, the good news is that it sounds more and more likely like you've found something that would cause a small vibration.
7/29/23 6:05 p.m.
My experience is that if it is a staked U joint, a driveshaft shop would not want to touch it, they would rather build you a new driveshaft for $700 or so, maybe more.
Practically speaking, if it is not actually binding, it's probably fine.  Maybe 90% of the cars on the road with IRS and a U joint in the driveshaft have a joint that indexes like that.  It only becomes a problem when it seizes.
eastsideTim
7/29/23 8:33 p.m.
It does appear to be staked, no removable clips holding it in.  Will have to see if someone local deals with it.  It looks like the Dorman replacement is under $700, but the factory Mercedes part is over $1200.  Maybe I will be reinstalling it and hoping the bearing and the giubos were the main issue.
cFPqGQgIg47H9xrxgKCeaOgXFz4aXqoQ4IUam8claWR8uJ5kntd9dFgAwLiXtxJF
