cyow5
cyow5 HalfDork
2/4/25 9:14 p.m.
DaewooOfDeath said:
cyow5 said:
In reply to DaewooOfDeath :
How much heat or how does it happen? Your wording is strange. The how is much easier to answer though. Any time you compress air quickly, it heats itself up much faster than it can heat up what compressed it. This is referred to as "adiabatic", and there are simple equations for telling you how much heat is generated. This is why we need intercoolers when running any appreciable amount of boost. How much heat depends on where you are on the compressor efficiency table. This is what determines the limit Codrus mentioned above. At some point, the extra heat negates some of the extra power, and OEMs tend to draw a more conservative line than aftermarket tuners because the OEMs are aiming for power on the nth pull and not just the 1st.
When looking at efficiency, you need to basically audit where all the heat is going. Heat lost to the intercooler is bad. Heat lost to the exhaust is bad. Turbos are good when they reduce the heat lost to the exhaust while losing little heat to the intercooler. There's your efficiency sweetspot. VVT helps a ton here by enabling more power with less boost (and therefore less heat). In fact, a supercharged car can see a drop in boost when running better cam timing despite gaining power. (I've seen threads online like "why did my boost drop?")
I understand this, and I am familiar with "good" boost loss when you put better heads or a bigger cam on an engine without changing the supercharger (or even turbo, depending on the flow limits).
What I'm wondering is if we tune the supercharger to be at its efficiency sweetspot at, for example, 12 psi, does it care from an abiatic standpoint if that 12 psi is with super mild cam timing or if it's with ideal cam timing?
That's not how you'd do it though. If you wanted dead flat torque, you'd figure out the boost you need at each rpm - not a flat boost number. So with optimum cam timing, you'd need less boost and therefore less heat. Even at peak compressor efficiency, adiabatic heating is very considerable, and peak efficiency is a function of both boost ratio and mass flow. In other words, even holding boost flat wouldn't give constant efficiency over the full rpm range.
Ditching VVT is the major flaw; VVT has done wonders for enabling dual-purpose engines that can be efficient and powerful rather than having to choose.Turbo response these days is as fast as the throttle (low pass filters on the throttle intentionally slow it down), so they make a pretty tough combo when calibrated well
DaewooOfDeath
DaewooOfDeath SuperDork
2/4/25 9:57 p.m.
I have been enjoying working through this thought experiment, as this runs tangentially to numerous thoughts I've had, posted about, and continue to have.
Prius doesn't just use 'mild little camshafts' though, it uses a modified Atkinson cycle which trades power for efficiency. Adding forced induction basically turns that into a Miller cycle. Which is great, but doesn't seem to be what you're looking for either. It may not have VTEC (does have VCT though) or high flow ports, but are those really any more 'fancy' than forced induction?
If you're just talking about taking a ~1.5L economy engine, beefing up a few parts, and adding forced induction, pretty much every manufacturer has done that now and it works great. The big difference I can see from what you seem to be poking at is that it also eliminates the need to rev, which is actually a good thing for economical power production.
Running at 8k rpm is much less efficient than 4k rpm. For starters, there is a lot more friction. Some of this comes from things like the stiffer valve springs needed to rev that high too. Based on the BSFC and thermal efficiency charts I've seen, all seeming to peak in the 3k-4kish range, it seems likely that overall efficiency in general is highest at these speeds too... Which would make sense why economy engines are thus cammed for that range too.
So while you may be able to use lighter drivetrain components with the lower torque at higher rpm, there are even greater efficiency losses to be had up there as well. Ever seen the Top Gear where they run a Prius flat out vs an E90 M3 (at the Prius speed) in a fuel economy test? Spoiler: The M3 wins.
At low throttle and low rpm, the smallest and mildest engine wins the economy contest. However, as power needs increase, this doesn't hold true. If you have to run an engine above ~4k rpm to get the desired power, you're generally losing efficiency vs a more (peak) powerful engine running the same power in that sub-4k rpm range.
On to the forced induction. What you described for equal torque across the rev range is not something that a supercharger would be used to do. This is because even the smallest cammed naturally aspirated engines make peak torque in the mid-range rpms. So that would be your point of lowest boost pressure. You'd need greater boost both above AND below that point, with the more boost needed the further you are away. That's probably why ridiculously (artificially) flattened torque curves didn't start appearing until the advent of more advanced computer controlled turbo systems.
So now what you need is a turbo that can make significant boost at very low rpm, which means it will be less efficient on that engine at very high rpm. This is where you run into the excessive heating of the intake charge to maintain the desired output.
This is very interesting. Thank you for writing it all out. There are a three quasi educated guesses I'm making that might be mistaken.
The first is that drivetrains capable of handling high loads eat up considerably more power than lighter drive trains. I am basing this on the differences between engine dynos and chassis dynos for the same engines. The extreme case is with trophy trucks. It's not uncommon for an 800 hp motor on an engine dyno to be around 500 wheel horsepower in a trophy truck. I don't know how those losses are divided, but I'm assuming a TH400 capable of handling both 600 lb ft and the massive shock loads associated with jumping (ie, constantly gaining and losing traction) is a major component of that loss. I compare this with something like a stock Miata, where the drivetrain loss is usually somewhere in the high 20 or low 30 hp range.
I realize tires are a part of this as well, but we're still talking about a Miata losing 270 less horsepower between the engine and the road. The assumption I'm making here, that might not be realistic, is that it's not just a flat percentage of power lost in the drivetrain, but something closer to an absolute number. Ie, it takes a lot of power just to turn the drivetrain in a trophy truck, and that if we put a Miata 1.6L in that trophy truck and connected it to that beefy TH400, the truck would barely move. As with your Prius top speed example, that 1.6L trophy truck, constantly struggling to reach its 34 mile per hour top speed, might also get worse fuel economy than the 800 hp monster simply because it would always be working so hard.
On the other hand, assuming the drivetrain survived long enough to make a dyno pull, that 800 hp trophy truck engine installed in a Miata would make something like 700 wheel horsepower, not 500. I am extrapolating that to mean that, from an OEM point of view or from the point of view of an enthusiast who wants to exceed 4 miles per gallon, we should try very hard NOT to require a drivetrain that can survive 600 lb ft and high shock-loads.
The second assumption I'm making is that a T5, rated at 300 lb ft of torque, can be made very small and very light, while a comparable drivetrain rated at 600 lb ft of torque, like a TKO, needs to be much heavier, much larger, and much more expensive. In the specific cases of the T5 and the TKO, the TKO is about double the weight, around quadruple the price, and about 30% larger. Avoiding the need for a TKO, it seems, is thus a significant cost and packaging benefit, along with a bunch of smaller perks like T5s being nicer to shift.
Third, I'm assuming that those BSFC numbers you reference (and that I've seen as well), are more a consequence of engines being small than engines being inherently efficient at 3-4k rpm. Ultra efficiency optimized ICE engines, I'm thinking busses and ships, tend to operate at the lowest RPMs they can get away with. My assumption was therefore that we don't optimize 1.5L economy car engines for 1200 rpm peak torque because that engine would struggle to make 30 hp, not because it wouldn't be efficient to do so. We cam them to make power at 3-4K rpm because gets us close to 100 hp, which is enough, and a 1.5L engine losing efficiency at those higher rpms isn't enough to offset the benefits of being small displacement. Ie, if we can get 40% BSFC from a 100 hp, 4 liter engine at 1200 rpm, or 35% BSFC from a 100 hp, 1.5 liter engine at 4,000 rpm, the 1.5 is going to get you better fuel economy inspite of being slightly less efficient in terms of BSFC.
I need to stress, these are all assumptions I'm drawing from inference. I don't have a laboratory full of equipment, and I certainly haven't tested any of these assumptions myself.
DaewooOfDeath
2/4/25 10:08 p.m.
I agree we don't want a flat boost curve. The centrifugal idea was specifically to create a rising boost curve. Ie, to make a linear compensation for tiny cams at higher rpm.
I also agree that VVT is a good idea. That said, aren't we still limited by the actual size of the lobes? I thought VVT only adjusted LSA.
As for turbos, maybe I'm getting non-representative experiences. I had a turbo Tiburon with a modern Garrett GT25 with a 54mm impeller. It was very laggy. I also had a Genesis Coupe 2.0Turbo with the stock turbo, and it was noticeably laggy.
Would it be possible to get a responsive turbo and then tune it to do nothing at 2k rpm, a little at 4k rpm, and then a lot at 8k rpm? By responsive I mean transient response, not the absolute lowest RPM it will make a certain boost number. I specify this because Tiburon, for example, would technically reach 18 psi at 3,000 RPM, it just took several seconds to get there.  The Genesis Coupe likewise would technically do 14 psi at 2k rpm after a long delay. The Tiburon was still a little delayed at 7k rpm, and the Genesis didn't get to "not noticeable" levels of lag until over 5k rpm.
DaewooOfDeath
2/4/25 10:18 p.m.
Also, for clarification, the Sendy Club solved their problem - getting 1000 hp while staying under 450 lb ft - with turbos, a small displacement engine, and revving to 13k rpm. They also don't care about fuel economy or low speed driveability.
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) UltraDork
2/4/25 10:29 p.m.
I just read gt25 was big on a 2l? I don't think I've ever put a turbo that small on anything other than replacing a stock k03 in a vw laugh
you can get near zero boost at all times as long as your wastegate flow is good enough. Few actually do this though.
DaewooOfDeath
2/4/25 10:32 p.m.
I didn't like that turbo set up very much. :)
You can actually see the lag in this video. https://www.youtube.com/watch?v=tkHflbP7-_0&t=1437s&ab_channel=BenGarrido
alfadriver
alfadriver MegaDork
2/4/25 10:34 p.m.
OHC heads don't have to be tall. And an under square engine wants to spin fast- so all of the extra pushrod hardware is a waste.
BTW, the latest engine designs are oversquare- the longer stroke helps with efficiency.
DaewooOfDeath
2/4/25 10:37 p.m.
In reply to alfadriver :
I thought undersquare meant small bore, long stroke?
Driven5
Driven5 PowerDork
2/5/25 3:31 a.m.
I agree that more robust drivetrains incur losses, losses are closer to a number than a percentage, and larger engines naturally run slower while smaller engines naturally run faster. But I think that's missing the forest for the trees.
Manufacturers are chasing tiny fractions of both economy improvements and cost reductions, yet they've chosen to trade rpm for torque in light passenger vehicle sized gasoline engines, despite the heavier and more expensive drivetrain requirements.
A 300 ft-lb T5Z is only ~25 pounds lighter than a 600 ft-lb TKX, and much of that is in the case.
The peak efficiency range or rpm for gas engines appears to be relatively consistent between 375cc and 750cc per cylinder, as well as between N/A and FI. Cams and/or boost for significantly higher rpm are both things that decrease rather than increase efficiency.
Trying to make 100hp the most efficient way possible: You could run a Honda L15B7 (1.5 T) above peak efficiency at 4500 rpm and consume 7.4 gal/hr, or a GM LV3 (4.3 N/A) right at peak efficiency at 2500rpm and consume 6.2 gal/hr.
DaewooOfDeath
2/5/25 3:58 a.m.
I defnitely agree that a steady 100 hp is more efficient with a 4.3. But putzing around with very tiny bursts of 100 hp - which is what we normally do - I would be shocked if the L15B7 isn't more efficient on average. I would also be shocked if most of that advantage doesn't come from the L15B7 being much more efficient at making 15 hp at 1200 rpm - ie, putzing between red lights.
As for the current trend towards more torque and less RPM, isn't that more about "torque reserve" and the massive bloat of modern (North American) vehicles? It doesn't seem to be very hard to be more efficient than the average North American car or truck, what seems to be difficult is remaining somewhat efficient when your average family transportation weighs 3 tons. I ask because here in Japan the very efficient - 70 mpg or more - kei car hatchback thingies are always able to rev 6k rpm or higher, with many much higher.
I'm surprised how close the TKX is in weight to the T5. That's really cool.
alfadriver
alfadriver MegaDork
2/5/25 8:22 a.m.
Sorry, I got it backwards. Either way, pushrods offer no advantage.
Driven5
Driven5 PowerDork
2/5/25 12:16 p.m.
DaewooOfDeath said:
...most of that advantage doesn't come from the L15B7 being much more efficient at making 15 hp at 1200 rpm - ie, putzing between red lights.
Correct. I talked about that in my first reply, and that's why the trend is towards half sized turbo engines. I think we may be starting to zero in on the 'sweet spot' for a variety of output ranges. As much as I've enjoyed thinking it through, I guess hadn't fully been following your intent.
So continuing with the L15B7:
If I'm following correctly, you would use FI to create a similarly flat torque curve that basically wraps around the 240 g/kwhr contour line where it's 166Nm at 3krpm, and then extends out equivalently flat to make 130kW from 155Nm at 8k rpm. Your supposition is that when putzing around in around the same vehicle, the 230Nm capable drivetrain will incur significantly more loss in efficiency vs the 166Nm capable drivetrain, than the additional losses from the 8k+ and higher boost (with equivalent durability and reliability) rotating assembly? Additionally, that a centrifugal supercharger would match the turbo efficiency? Basically providing VTEC like efficiency down low with power up top, but brute forcing the latter with a supercharger? Honestly, I'm just not seeing the benefit being there. Meanwhile, the efficiency when you actually use the additional high rpm and boost will only drop off further too. Even with VTEC, and regardless of eco or sport focused, Honda is going with turbo supporting low end torque more than RPM.
Sure torque overhead is a thing, but as felt and used it's more of a mid-throttle thing than a WOT throttle thing. What you're seeing there in the 2k-3.5k rpm for the max torque is not actually used for anything more than marketing materials. That's not how the PCM is programmed to operate, nor is that how most people would drive it even if it's technically there. If I want 60kW to accelerate, it's not going to let me just go full WOT at 2500 rpm, nor would I choose to. Even if it were entirely cut off per the 166Nm example, throttle and transmission programming could result zero difference to what the driver experiences, outside of intentionally being obtuse with manual gear selection... Making that a bit of a moot point IMO.
Taken to that Kei car extreme, and ignoring driver perceptions: I do not see any data indicating that increasing the the rpm and boost (only in the added rpm range) to get an 85Nm 660cc Kei car engine to 130kW (@15k rpm) and dropping the whole lightweight powertrain into a new Civic or CRV, would actually result in an overall more efficient vehicle than with the existing torquier and heavier L15B7 powertrain.
I have no first hand experience with Kei cars, but I feel like I've heard other things before like this comment from an importer...
Kei cars are not terrible on fuel economy but they aren’t super either. They are often advertised with numbers such as 30km/l (70mpg) however real world driving conditions such as turning on the AC during a hot day and luggage/passengers brings that number down to about 30mpg. The small engine also encourages revving which also raises fuel consumption.
alfadriver
alfadriver MegaDork
2/5/25 1:56 p.m.
Fwiw, 15 hp will move most vehicles 50 mph steady.
2/5/25 3:01 p.m.
Note that the ND Miata has a high torque engine as Miatas go, and it's not because it has to lug about a bunch of weight :) It's because it's faster in more conditions and easier to drive. Miatas have been gaining low end torque since 1994.
About drivetrain loss: it's both a percentage and a fixed amount. Dyno operators will use one or the other to "correct" to a flywheel number depending on how they want the results to work out. But there are some fixed losses and some that are directly related to the rate of acceleration. I've done tests on a dyno using different rates of acceleration and saw the measured output drop from 151 hp to 145 hp on a stock Miata with no other changes. So if you're using an inertial dyno and you put an 800 hp trophy truck on it, you'll see much higher drivetrain losses than a 150 hp Miata would because it's simply having to work harder to overcome the inertial losses inside the transmission. But you've still got friction and losses from the right angle turn in the differential.
DaewooOfDeath
2/5/25 10:36 p.m.
One cam for two cylinder heads, not as wide, right? Ie, a pushrod boxer engine will be narrower and less complex than an OHC design.
alfadriver
alfadriver MegaDork
2/5/25 10:54 p.m.
For a v engine it makes sense. For an I4 it does not. A single cam can be packaged in a very tight spot for keep the head short enough.
And for your theoretical 1.5l, it's a really small engine already. Lots of modern dohc 4v versions fit in really tight spots.
DaewooOfDeath
2/5/25 11:01 p.m.
Yes. What I was mostly thinking is that you could use a very low RPM optimized cylinder head, intake manifold etc to make that 240 g/kw island appear very far to the left hand side of the graph, which is where most of your driving will be done. At low rpm, basically make it NA, or even clutch the supercharger so that it doesn't even engage until some higher rpm. In this sense, you basically have a very low horsepower NA engine optimized to be very efficient in the 10-30 hp range, at very low rpm, where we do most of our driving.
Then you brute force high rpm performance with a rising boost curve to keep the torque curve flat and extending out to some high rpm. A centrifugal blower seems like the easiest way to do this, but you could do it with a huge wastegate as well. This will not have very good BSFC at higher RPM, and we'll absolutely get crushed in the Top Gear Prius test. It will also not make as much absolute power as if we just used a turbo. These are the downsides.
But the benefits of the brute force high rpm boost are potentially as follows:
1. We usually have what is effectively a very efficient NA engine optimized to make 15-30 hp at low rpm. This is good for normal driving fuel economy, gives us a nice tame idle, allows us to have very high swirl (ie not very high flow) cylinder heads, and to use cheaper valvetrains like SOHC or OHV. This is, in other words, a miniturized version of a city bus engne - basic valvetrain, optimized for low rpm, very mild tuning - 90% of the time.
2. By brute forcing a rising boost curve, we can keep the torque curve flat at whatever the desired torque is. If we're designing a next generation Honda Fit, we might aim for 85-100 lb ft at 1500 rpm with cam timing, and then extend that 85-100 lb ft out to 6k rpm with boost. If we're designing the next generation Miata, optimize the engine to make 150 lb ft of torque with cam timing, and then brute force extend that 150 lb ft out to 7500 rpm. If we're designing the C9 Corvette ZO6, make it 400 lb ft of torque and brute force boost that to have a flat torque curve stretching to 9000 rpm. In all cases, we can hit our hp targets with less torque than a normal turbo engine or a larger displacement NA engine. Our 750 hp Corvette C9, for example, would be right on the edge of being able to use a T5 transmission from a mid 90s Mustang.
3. A turbo big enough to brute force boost at high rpm would seem to be pretty laggy in transient response, I think. With a centrifugal blower, you could oversize the impeller to only work at high rpm without that concern.
4. By keeping the boost restricted only to the highest rpm ranges, we allow a higher compression ratio and better thermal efficiency at low loads. Unless my understanding is mistaken, engines are usually more vulnerable to knock at lower rpms, less vulnerable as revs rise. My Genesis Coupe had about 15 psi of boost, and ran a compression ratio of 9.0:1.  It was also enriching the mixture quite a bit. A lot of this is because it needed to survive 15 psi at only 3000 rpm or, if the driver had no mechanical sympathy whatsoever, as low as 2000 rpm. If that was 2 psi at 2k rpm, 5 psi at 3k rpm, and 15 psi at 6k rpm, it could probably get closer to 10:0 compression with less enrichment.
The benefits to myself specifically, as a guy who has to pass a strict vehicle inspection and wants more power out of his NB Miata, are as follows, potentially:
1. I can swap in the cams from a Kia Sephia and get a nicer idle, better fuel economy, nicer around town manners, and better response coming out of slow corners.
2. I can get my desired 220-ish wheel horsepower at 7000-ish rpm without the need to worry about the transmission surviving. (Rotrex claims 240-ish with stock cams.)
3. The rotrex blower system I'm looking at with lust in my heart could be removed and reinstalled in a couple days when it comes to inspection time. (Which is the number one reason I'm reluctant to do a turbo. Number two reason is that I'm tired of laggy turbo engines.)
alfadriver
alfadriver MegaDork
2/6/25 8:31 a.m.
Is one of your assumptions that under boost, the engine runs rich?  Kinda seems like it.
Modern engines don't really need to do that- it can run stoich at peak power and torque for quite a while without damage. It's why small engine boost at low speeds so much- they really don't drop off efficiency with some boost.
There are older components that will need some cooling, but it's not a lot, and generally when the engine is really working hard for a really long time it will eventually go rich.  But that will eventually go away as regulations are really cutting back on when enrichment will be allowed.
And it's not super hard to make close to 200hp with a small turbo sized to make low speed boost quickly so that the engine can spend a lot of time between 1500-2000 rpm where it can be most efficient.
DaewooOfDeath
2/6/25 11:12 a.m.
My Genesis was down as low as 10.8:1 afr on the dyno before mods, but that's not really the point.
But my basic assumption is that, for any given fuel mixture, and any given compression ratio, knock is more likely at lower rather than higher rpm. Ie, we'd be able to run my old Genesis at something more than the stock 9.0 compression with the same boost and same mixture if it only ever saw 15 psi over 6k rpm. Higher compression, all else equal, is higher thermal efficiency.
The efficient 200 hp turbo engine you mention running 14.7:1 afr on boost would seem even more efficient if it could maintain those conditions while also bumping up the compression. As such, if rpm helps knock resistance, a rising boost curve seems useful on efficiency grounds.
rslifkin
rslifkin PowerDork
2/6/25 12:20 p.m.
Higher compression with boost is already possible if you have an efficient chamber design that doesn't need a ton of spark advance, variable valve timing, good boost control, etc.  For example, on the turbo version of the Mazda Skyactiv 2.5, they drop compression from 13:1 to 10.5:1, but that's still a fairly high compression engine.  And the new turbo I6 in that family is listed as 12:1 compression.  Honda's 1.5 liter turbo in the Civic, CR-V, etc. is also over 10:1 compression.  And then you've got stuff like Nissan's variable compression thing.
NOHOME MegaDork
2/6/25 12:30 p.m.
In reply to STM317 :
Why was that toyota echo engine so slow to respond to the throttle?
Driven5
Driven5 PowerDork
2/6/25 2:46 p.m.
As noted, most modern (direct injection) turbo engines seem to be running ~10:1 compression, so you're not wrong there and they're already a step ahead of what you're thinking.
Going back and rereading your original post, the "so far so conventional" statement actually covers most of the rest of the post too. As far as I can tell, most of what you've done is basically just the same mental gymnastics that have been used by (tens of?) thousands of people to justify aftermarket centrifugal supercharging for decades.
While it may be less than conventional to start with an already low torque engine, and possibly even de-cam it further from there, it's ultimately a pretty minor variation from a technical standpoint. So I don't think you're off base there in general either.
As far as I can tell, the main points of contention is regarding efficiency and the main limitation is high rpm aspirations. I do think the low rpm efficiency will be pretty good, and possibly as good or better than stock if de-cammed. Where I disagree is that I still do not think the overall efficiency will come out better than what has been done with VTEC and/or turbo's... Which is ok if you don't need it to. With low flow heads and small cams, there will also be diminishing returns as the engine runs out of ability to flow. The supercharger will lose efficiency and transition from generating more power to generating more heat as boost and revs continue to rise. So there is also a limit to the rpm range (and thus max hp for a given setup) that this can be useful for. The goal would be for that to happen above the desired range, but where that happens for any particular example would require a bunch of data I don't have and math I don't know.
Ultimately though, the specific use case you've laid out for yourself looks good for a centrifugal supercharger. So now that we've backed into the REAL purpose of this thread, justifying centrifugal supercharging your Miata: Consider yourself enabled. devil
I'm not sure the Sephia cams will be worth the effort vs just supercharging it as-is, especially with the added tuning I expect would be involved. Either way, I look forward to future updates on both driving impressions and real world fuel economies. angel
alfadriver
alfadriver MegaDork
2/6/25 3:20 p.m.
Back 15 years ago, F did our first DI engine that had 10.5:1 compression and was capable of over 400 hp from 3.5l. It was limited by the trans, as you originally noted- so only 365hp
Just as I retired, I was working on its truck cousin engine originally released in 2012 and we had to push exhaust temps to 950C  because it had to meet very modern CO rules
It's been a long time with high compression turbo engines.
For the most part, knock is just as hard at high speed as low now. Low speed combustion still sucks, though.
The one thing I personally like researched is how far open valve PFI could be pushed to be a cheap version of DI. The spray models have gotten really good thanks to DI.
DaewooOfDeath
2/6/25 10:06 p.m.
Yeah, the mental gymnastics are unfortunately constrained by a lot of things. If I lived in the US, it would be a lot easier, and I probably wouldn't do a centrifugal blower. I would be looking at an engine swap instead. Probably something with VTEC. Either a J series or K series, probably the J. A V8 swap would be cool as well, but the stock Miata drivetrain is really fun and sweet shifting and I'd like to keep it. I don't really like T56s from a feel standpoint.
Unfortunately, it's very difficult to get a motorswap to pass inspection here in Japan. So that's more or less out of the question until I get good at using the Japanese legal code to my advantage (probably 5 or more years out, considering how long it took to get good at such things when I lived in Korea).
So I need to stay BP powered. I initially was looking at positive displacement blowers, but the only ones I can find require strange stuff like dual throttle bodies and don't make that much power. I was also looking at turbos, but I've had turbo swapped I4 engines before and didn't really like them. See the video I posted before of my old Tiburon. Also, swapping the turbo kit on and off every inspection will be HARD.
So that really just leaves an NA build - which everything I've read seems to indicate is a massive money pit with poor returns on a BP - or a centrifugal. Ease of swapping on and off really is the main attraction, with throttle response being a relatively distant second place.
The idea for decamming the engine comes from two places. The first was my experience with centrifugal equipped LS stuff, which I thought was great. It was like somebody had created a 5.7L version of an S2000.
The second is an engine building simulator that's admittedly not very realistic. https://www.automationgame.com/enginedesign
DaewooOfDeath
2/6/25 10:09 p.m.
What's your opinion of the Nissan variable compression? I saw a teardown of one and it looks like a lot of extra moving parts in the highest stressed parts of the engine.
nuwdLjv1pDEsiyslF4Z9wxbT6hbRgKeREaKdcdFE6MRpmXMQItVhky5LI6jS1Cb0
