16vCorey
16vCorey PowerDork
5/29/14 9:18 a.m.
I've had issues with stock rear springs on and E30. What I did was pop them out with a prybar (after dropping the suspension as much as I could), then compress the spring with a spring compressor on the work bench, then use bailing wire between the coils to keep it compressed, since there's not much room for a spring compressor in the suspension. Then set the spring in place and snip the bailing wire off. Presto.
You can change aftermarket sport/lowering springs pretty much by hand once the rear shock and sway bar is disconnected.
bravenrace
bravenrace UltimaDork
5/29/14 9:24 a.m.
In reply to Giant Purple Snorklewacker:
Thanks for the help to you and all the others!
SEADave
SEADave Reader
5/29/14 2:01 p.m.
Giant Purple Snorklewacker wrote:
bravenrace wrote: In reply to Giant Purple Snorklewacker: So no spring compressor required?
I've never used one in the rear. That is what the foot pushing down on the hub is! There are rubber bushings in the upper/lower inner and trailing arms that have some pre-load you will have to overcome with your leg as well as some rubber spring pads that have grown attached to the springs... so yank them about a little or twist them around to loosen them up.
Yep, when I was replacing the axles and rear shocks on my E36, one of the springs literally just fell out. All I had to do was reach up and put it back in. The suspension definitely has enough travel to remove the spring with no compressor.
bravenrace
6/1/14 5:02 p.m.
Thanks for all the help guys. I R+R'd the springs yesterday. It was about the easiest spring replacements I ever did. All I had to do was disconnect the bottom shock mounts. Took about 45 minutes to do the the whole job!
unevolved
unevolved Dork
6/1/14 9:34 p.m.
That's awesome! My left rear wouldn't sag enough without loosing one side of the halfshaft, glad yours went so well!
bravenrace
6/2/14 7:18 a.m.
In reply to unevolved:
Does yours have the sport suspension? If not, I'm wondering if the shorter springs on mine is what may have made the difference.
ohXvMLzTRQKIg1D4YuY1Vm1oORPBo2WcVQvA6pzLAppG7hIQHytP7BdD5M7FudVH
