codrus (Forum Supporter)
10/11/21 2:13 p.m.
tomtomgt356 (Tommy) said:
This is going to depend on the seat you pick, there aren't many that fit a Miata without cutting stuff like that.  FWIW, the Recaro Pole Positions in mine did not require notching the tunnel.
The seat you pick depends on how much you like donuts and cheeseburgers. Any seat that will fit without requiring a tunnel notch will require you to be built like an F1 driver.
Heh, I am DEFINITELY not built that way -- 6' and 240 lbs.  It does partly depend on where your fat is distributed though.
steronz
steronz Reader
10/11/21 2:27 p.m.
Height matters too, as I would have needed to notch less if I could get more layback, but the layback was determined by leg length to roll bar.
One thing I learned for sure during that whole process was that millimeters matter...
iWkxeY3VeD38ArHzSmo6sUtCB1RviB8G7Jz7CphjreSO1WYDg9RSNRdj501MdTtp
