93EXCivic
93EXCivic MegaDork
1/16/13 5:27 p.m.
How will a Fiat single cam hold up to a small shot of NOS like 50 shot or less?
GameboyRMH PowerDork
1/16/13 5:31 p.m.
Only one way to find out!
No but seriously I'd give it a 20% chance of catastrophic engine failure.
RexSeven
RexSeven UltraDork
1/16/13 5:38 p.m.
mad_machine
mad_machine MegaDork
1/16/13 5:50 p.m.
the fiat 128 engine should hold up fine. Aluminum head on an iron block. Just do not try for the 100hp shot
JThw8
JThw8 PowerDork
1/16/13 6:02 p.m.
mad_machine wrote: the fiat 128 engine should hold up fine. Aluminum head on an iron block. Just do not try for the 100hp shot
Agreed, especially a semi stock motor as they aren't very high compression.
And if/when you blow it up, give me a holler, I have a few spares ;)
mad_machine
1/16/13 6:12 p.m.
yes.. I think they ran 8:1 compression to get past the 70s emissions requirements?
GVX19
GVX19 Reader
1/16/13 6:42 p.m.
I have 20psi on a stock 1.1L. So I dont see why you cant run a 50 to 100 shot.On a 1.3L I trust your using FelPro head gasket. # 21195 PT-2
93EXCivic
93EXCivic MegaDork
1/16/13 8:53 p.m.
In reply to GVX19:
What does that head gasket do?
aussiesmg
aussiesmg UltimaDork
1/16/13 8:58 p.m.
93EXCivic wrote: In reply to GVX19: What does that head gasket do?
Seal the head to the block usually
Swank Force One
Swank Force One MegaDork
1/16/13 9:02 p.m.
If it was an f2t you couls push 150-200.
mad_machine
1/16/13 10:02 p.m.
but that's not important right now
SVreX
SVreX MegaDork
1/16/13 10:08 p.m.
I did it to my Yugo with a 1.3L EFI. Dry shot. 75 hp, I think.
Didn't hurt, but didn't help a lot either.
poopshovel
poopshovel UltimaDork
1/16/13 10:53 p.m.
I'll give you 5 dollars if you swear you'll never say/type "NOS" again.
It's (nitrous oxide, that is...not "Nitrous Ox Side") an easy, cheap, "afternoon project" way to make power with a motor you don't give a E36 M3 about. Use common sense. Err on the side of too much fuel. Monitor AFR if possible. If not, make a pass, pull a couple plugs, adjust jets accordingly. Have fun, use a bottle warmer to keep the pressure ~1000 PSI. Speaking of 1000 PSI, carry that bottle like a baby. Seriously.
If it doesn't help a lot on a motor with less than 100hp, you've berkeleyed something up. We gained 45 hp on the first challenge crx; 50% increase over stock. You'll feel that. Lot of trial and error with jets though.
tuna55
tuna55 UberDork
1/16/13 11:02 p.m.
poopshovel wrote: I'll give you 5 dollars if you swear you'll never say/type "NOS" again.
Excellent, thank you Poopshovel.
yamaha
yamaha SuperDork
1/17/13 1:13 a.m.
Wait, where are you finding New Old Stock shots?......hopefully they're shots of NOS scotch.
RoadRaceDart
RoadRaceDart Reader
1/17/13 1:41 a.m.
What...it's not NAAAAAWS Yo! and said with your hat at a funny angle while granny shifting your 28 speed Hon-derrr?
I'm shattered......
Raze
Raze SuperDork
1/17/13 6:17 a.m.
In reply to yamaha:
owning an old Fiat, when I read NOS I thought New Old Stock, and then for some reason I remembered there's a new Fiat, and thought we were about to see some NOx on a new Abarth, but I'll take anything I can get, so please, continue
JThw8
JThw8 PowerDork
1/17/13 6:34 a.m.
Raze wrote: thought we were about to see some NOx on a new Abarth,
Don't tempt me....
phaze1todd
phaze1todd Reader
1/17/13 7:02 a.m.
What...it's not NAAAAAWS Yo! and said with your hat at a funny angle while granny shifting your 28 speed Hon-derrr? I'm shattered......
But Dom doesn't use Nawz!
SCARRMRCC
SCARRMRCC New Reader
1/17/13 7:26 a.m.
poopshovel wrote: I'll give you 5 dollars if you swear you'll never say/type "NOS" again. It's (nitrous oxide, that is...not "Nitrous Ox Side") an easy, cheap, "afternoon project" way to make power with a motor you don't give a E36 M3 about. Use common sense. Err on the side of too much fuel. Monitor AFR if possible. If not, make a pass, pull a couple plugs, adjust jets accordingly. Have fun, use a bottle warmer to keep the pressure ~1000 PSI. Speaking of 1000 PSI, carry that bottle like a baby. Seriously. If it doesn't help a lot on a motor with less than 100hp, you've berkeleyed something up. We gained 45 hp on the first challenge crx; 50% increase over stock. You'll feel that. Lot of trial and error with jets though.
ACTUALLY, when referred to as NOS, it stands for Nitrous Oxide System.
so, he is using the term wrong.. like Kleenex.
hrdlydangerous
hrdlydangerous HalfDork
1/17/13 8:36 a.m.
Did someone say Naws?
Raze
Raze SuperDork
1/17/13 9:34 a.m.
In reply to JThw8:
You found my post, aimed at you, touche sir, touche
1/17/13 11:50 a.m.
In reply to hrdlydangerous:
LOLOLOLOL
RealMiniDriver
RealMiniDriver SuperDork
1/17/13 3:07 p.m.
Don't tempt me....
Doo eeeet.
GVX19
GVX19 Reader
1/17/13 4:52 p.m.
The Felpro head gasket is a steal shim ,with something that looks like wax on it. If you have to change it at the track you wont have to clean the head or block. Or if you have to take the head off you can reuse it.(You may wont to spray it with copper coat first.)
pluUYciB2Uuw16wnYcRKXRrjTBQ1Gn2WVv6og4ExlXqysA5eVtr4L3XbZvFDMRv3
