Dusterbd13
Dusterbd13 MegaDork
2/2/25 5:09 p.m.
It was sheets of fiberglass that you bent into shape, and then peeled backing off of, or put vacuum to the bag of to make the pre-soaked resin cure. Used for large, flat, in place panels. It was hot rod, car craft, or grm article sometime between 1995 and last year.
I may be having an acid flashback, but it seems way too boring for one.
stafford1500
stafford1500 Dork
2/2/25 5:59 p.m.
We used a fiberglass and honeycomb product with scoring on one face that allows bending. I can find out the manufacturer info next week.
lrrs
lrrs HalfDork
2/2/25 6:39 p.m.
Google prepreg fiberglass. May be what you are looking for
Prepreg fiberglass is a composite material made of fiberglass and a partially cured resin. It's used in construction and as a protective layer for other components.
wawazat
wawazat SuperDork
2/2/25 6:58 p.m.
I recall seeing a product like that but it also had a stainless steel mesh like wire cloth embedded in it.  About 1cmx1cm squares.  That mesh allowed you to bend the product in to a shape and have it maintain that shape while the resin cured.  It was very cool.
Mr_Asa
Mr_Asa MegaDork
2/2/25 7:06 p.m.
Prepreg usually takes an oven to cure.  I've never seen one that did it in-place.
I guess if it were kept anaerobic and peeling the sheet allowed it to catalyze with air?
jgrewe
jgrewe Dork
2/2/25 8:03 p.m.
Maybe UV curing resin?
buzzboy
buzzboy UltraDork
2/2/25 8:25 p.m.
I've seen water cured prepreg. That was neat stuff
Dusterbd13
Dusterbd13 MegaDork
2/2/25 9:44 p.m.
Yeah! It was a prepreg with something in it to keep shape while it cured. I dont remember if it was air, vacuum or uv cure.
The article had them making ducting and enclosures.
I want to use it for a complex shape on the rear cab wall of a truck for a fiberglass sub box. Dont want to mix resin and mat in there.....
jgrewe
jgrewe Dork
2/2/25 10:19 p.m.
You might change your plan after you see the prices and quantities available. I played around with Sunrez resins years ago but it was too expensive to ship the quantities I needed.
https://www.fibreglast.com/products/sunrez-uv-vinyl-ester-prepreg-fabric
stuart in mn
stuart in mn MegaDork
2/3/25 11:32 a.m.
Here's a fiberglass patch kit that has the mesh already impregnated with resin, oddly enough you wet it with water to get it to set up.  https://www.amazon.com/J-B-Weld-FiberWeld-Automoitve-Repair/dp/B09BBGS7CN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=ATVPDKIKX0DER&gQT=1
Here's another one that sets up from the sun's UV rays.  https://www.kbs-coatings.com/kbs-patch?srsltid=AfmBOoraw-hv5a_EujiaWoJR-xPl4aEKk60CwSEZ4S66PgxTeiP2uD-I
QsUGBg2NG8VzJDT4jChhjIoVBqeOCLJnQDrcSLBesopPMNqjWXeXP7Ymk1ncHq77
