stan_d
stan_d Dork
10/10/13 10:28 a.m.
Well this is my first attempt at repairing fiberglass, it didn't go well. The resin didn't set up I put in the hardner. What can I do now?
aussiesmg
aussiesmg MegaDork
10/10/13 10:34 a.m.
Youtube, is making this too easy bro
http://www.youtube.com/watch?v=OlPqvX9WP-E
http://www.youtube.com/watch?v=i99hvludRUo
http://www.youtube.com/watch?v=rleMhHjKxDI
Don49
Don49 Reader
10/10/13 12:44 p.m.
Are you sure you had the correct amount of hardener? If you use too little or too much it will slow the curing. Also, it is temperature sensitive. Below 70 degrees will slow things dramatically. You can use a heat gun or hair dryer to warm(not heat) the fiberglass to kick start the cure.
stan_d
stan_d Dork
10/10/13 1:00 p.m.
I thought I put enough in apartmently not I give some sun bake time.
stan_d
stan_d Dork
10/11/13 8:33 a.m.
Is there any thing I can do about the non cured resin ? Put hardner on it ? Or do I have to clean off and start over.
stan_d
stan_d Dork
10/13/13 10:44 a.m.
After 3 days in the sun it finally cured.
lMf4WFzJD2p0pcT9gXJzuSKwKrZuW9S816Ks2EWmZtWb6vt8CTS4q9Q33xU7IZBo
