For your theme, you need to paint the car white, get yourself a white racing suit, a pipe, and a black hat.
i read that article some where, very interesting. I wouldn't mind the car in white, but a paint job is not in the budget. I'm holding out for black parts for the replacement panels I need
http://detroit.craigslist.org/mcb/pts/2638641201.html
Local to you in the right color with many parts left over to sell off.
Cool and somewhat rare Beretta rims
Buy some foam rollers, blue tape, sand paper and some Rustoleum in the can. $50 and you've got a paint job.
SyntheticBlinkerFluid wrote: Those Z24 Cavalier wheels look good on a Fiero.
needs moar ZQ8 Wheels...
FWIW, my experience with mid engined cars and autocross is that they typically like big front anti-roll bars, a good bit of shock (rebound) in the front. Use just enough rear bar to be able to tune the handling between understeer and oversteer. More rear bar tends to increase wheelspin, even with a MR set-up.
Good luck!
Gearheadotaku wrote: Brakes and clutch are working again! Took it for a few loops around the block and then started the dis-assembly work.![]()
Picture #2 is the drive for the water pump. Bizarre huh? Thats why I want to get an electric in here. Got a bonus at the junkyard this weekend, a scrape in the side of my Saturn.
Some thoughtful soul felt it would look better with a bit of white paint from his car but didn't discuss it with me first. Imagine my surprise when I got back to my car
Lucky for me it did "buff right out" Hurray for plastic cars!
thats a gilmore drive. The big city race cars use them to drive an alternator. Saves the weight of a tensioner
For AutoX, I'm kinda partial to Steve Hoelscher's tuning solution for MR cars.
on his DSP X-1/9 he ran no sway bars and 650f/600r springs.
He's done a similar solution on his MR-2.
Of course the issue is that for Challenge budgetary considerations, finding enough shock to control those springs is, um, tricky.
no sway bars allows for full use of the tire's lateral grip and the high spring rates still allow the car to transition quickly (also to compensate for the bad camber curve on his strut-based cars by limiting suspension movement)
Motorcycle shocks are a possible option.
Just a thought. Either way works as they are essentially two ways to skin the same cat.
turboswede wrote: Buy some foam rollers, blue tape, sand paper and some Rustoleum in the can. $50 and you've got a paint job.
or a harber freight hvlp during a sale, paper, tape, and some rustoleum or (my preference) valspar tractor paint from TSC for $30 a gallon. You're still around $50 and you'll have a much better paint job with less labor to make it look good. I have no idea why people roll paint on if they have a compressor that will run an hvlp.
Gearheadotaku wrote: A true fastback would be fine, but not this 1/2 way converted thing. This is a real GT. Different 1/4 panels, taillights, and deck lid.![]()
Although the true fastback is a pretty car (especially all in one colour), the hybrid look of what you have is distincitve and not without attraction. I'd leave it, after all, it is a bit of a bastard as it is.
Rob_Mopar wrote: For your theme, you need to paint the car white, get yourself a white racing suit, a pipe, and a black hat.![]()
I think that is Smokey Unick. Wildly brilliant before his death. Not so much after.....
Cotton wrote:turboswede wrote: Buy some foam rollers, blue tape, sand paper and some Rustoleum in the can. $50 and you've got a paint job.or a harber freight hvlp during a sale, paper, tape, and some rustoleum or (my preference) valspar tractor paint from TSC for $30 a gallon. You're still around $50 and you'll have a much better paint job with less labor to make it look good. I have no idea why people roll paint on if they have a compressor that will run an hvlp.
Because it is less messy, uses less paint and the finish can turn out just as well.
You won't find black Fiero panels that haven't started to get clearcoat peeling on the horizontal surfaces, at least not in $201X budget. I can't remember the last time I saw a black one with OEM paint that was in good shape. With the lighter colors you get lucky occassionally, but not black.
Sincerely,
Guy who unsuccessfully sought decent used black Fiero parts for years
Gasoline wrote: Neat car. What exhaust manifolds are on the motor?
It has cast iron center dumps. (Rams horns as I was groomed to call them) They will be sold when I get them off. I plan to use L98 Corvette tubular manifolds instead. I'll save a little weight and hopefully get a few dollars back in the budget.
I think those are 16" Beretta GTU rims. They did make a very similar wheel for the Cavalier, but they were 15".
Blitzed306 wrote: I had a 88 Formula, I miss it a lot
I had one too. It was white, autocrossed it with great success for 3 years. Sold it for what I paid and bought a L82 Corvette.
Per Schroeder wrote: FWIW, my experience with mid engined cars and autocross is that they typically like big front anti-roll bars, a good bit of shock (rebound) in the front. Use just enough rear bar to be able to tune the handling between understeer and oversteer. More rear bar tends to increase wheelspin, even with a MR set-up. Good luck!
Spring / shock / bar shopping is under way... Thanks for the tip!
Gearheadotaku wrote:SyntheticBlinkerFluid wrote: Those Z24 Cavalier wheels look good on a Fiero.I think those are 16" Beretta GTU rims. They did make a very similar wheel for the Cavalier, but they were 15".
I believe you are correct. I've seen them on Berettas, but usually Z26s. I saw that style on many Z24 Cavaliers.
