porschenut
porschenut HalfDork
5/25/23 8:33 p.m.
I have a minor one in my suby turbo, just went over all the hoses and checked clamps.  Any brittle rubber has been replaced and the engine is newly rebuilt.  Idle is just a hair low, what do you recommend spraying at clamps and such to see if there is a leak?  I have starting fluid but not real comfortable spritzing it all over the motor.  Heard water works but never tried it.  So what have you all used that didn't start a fire but changed idle RPM?
5/25/23 8:58 p.m.
Propane.  Use an unlit propane torch, with a hose stuck on the end so that you can direct it.
I used to use one with a piece of brake line on the hose so I had a Wand of Fueling to really pinpoint leaks.
If the idle is low, it's probably not a vacuum leak, if the engine is in fuel control (running closed loop).  You'll see the fuel trims change, you won't see a change in idle speed, unless it is a severe single cylinder vacuum leak where adding fuel will make a misfire go away.
dean1484
dean1484 MegaDork
5/26/23 10:39 a.m.
Get a smoke machine.
porschenut
porschenut HalfDork
5/27/23 9:51 a.m.
As it turns out idle is a computer set function and all I need to do is disconnect the battery and go thru a process to re learn.
j7VsBseo2qprJ6VZT07gZVLhGI85351qDrMkXfzGiQvanwYjRIOCm1oYeYFZdHq9
