Dusterbd13
Dusterbd13 MegaDork
4/24/17 9:56 p.m.
Thread from 2017:
New one on me. No matter what i do, it doesnt work. Tried switching sides for in/out. Tried directly grounding to the cage with a length of wire. Direct hot lead from battery to switch post. Nothing. Bought another solenoid, same thing. Returned for solenoid #3. Same. What am i missing????
BrokenYugo
BrokenYugo MegaDork
4/24/17 10:07 p.m.
Got the "S" trigger and "I" ignition ballast override posts mixed up?
If the bracket is grounded, you have power at the battery terminal, and you short the S terminal to the battery terminal with a screwdriver it will trigger and put power to the starter.
gearheadmb
gearheadmb Dork
4/25/17 6:55 a.m.
BrokenYugo wrote: Got the "S" trigger and "I" ignition ballast override posts mixed up? If the bracket is grounded, you have power at the battery terminal, and you short the S terminal to the battery terminal with a screwdriver it will trigger and put power to the starter.
What he said, exactly.
Dusterbd13
Dusterbd13 UltimaDork
4/25/17 7:03 a.m.
I will double check tonight. Maybe im just not getting a good enough ground. Done everything else, including confirming via stamping that im using the s terminal.
All im using is the s terminal, batter lig, and starter lug. I cant think that leaving the ignition lug unconnected would cause a problem.
gearheadmb
gearheadmb Dork
4/25/17 7:05 a.m.
In reply to Dusterbd13:
It is fine to have ignition terminal disconnected.
patgizz
patgizz UltimaDork
4/25/17 7:10 a.m.
Are you testing for 12v at the lug that goes to the starter or are you trusting the starter to be good as an indicator of the solenoid function?
Dusterbd13
4/25/17 7:13 a.m.
In reply to patgizz:
I jumed across the solenoid completely to hear the sound of the starter to make sure it will make noise when i get it. Starter will spin the engine when solenoid is jumped with a chunk of 8 gauge wire.
4/25/17 7:19 a.m.
If you activate the solenoid, do you hear a click or any noise coming from inside? I have a new solenoid but no Fords in my life, yours for the shipping.
Dan
Dusterbd13
4/25/17 7:33 a.m.
No noise from any of the 3 solenoids I have tried. I can't believe that I have found three bad ones in a row. Two new, one used.
But i may take you up on the offer anyway to have a spare.
Joe Gearin
4/25/17 12:23 p.m.
Did you buy them from Advanced Auto? I had two of theirs go bad--- when I asked the store manager, he admitted they had got a bad batch, and were changing suppliers. Perhaps you got a few of the old ones?
NOT A TA
NOT A TA Dork
4/25/17 1:24 p.m.
Ground the mounting bracket directly to the battery with a jumper. I'm thinking you don't have a good ground path through the cage to the battery. If the battery is grounded to engine and engine/drive line is rubber mounted you may not have a good ground path from cage to battery.
jimbbski
jimbbski Dork
4/25/17 1:31 p.m.
Just throwing this out there: Do you get 12V from the Ign. switch to the Solenoid when you crank the engine over? I had a Ign. key switch go bad that would work OK except when you tried to start the engine. That pin was dead. I just added a separate starter button to activate a relay that supplied power to the Ign. side of the solenoid.
Dusterbd13
4/25/17 1:45 p.m.
I took the switch completely out of the equation. So we can presently eliminate that possibility
Will jumper a ground directly to the battery tonight and see what happens. Poor ground path is all i haven't completely eliminated.
akylekoz
akylekoz Reader
4/25/17 2:04 p.m.
If its a fox chassis after a certain year they added a solenoid to the starter but did not remove the one on the fender. A little redundant but to remove the fender solenoid would have meant more wiring changes.
ultraclyde
ultraclyde UberDork
4/25/17 2:35 p.m.
Dusterbd13 wrote: I took the switch completely out of the equation. So we can presently eliminate that possibility Will jumper a ground directly to the battery tonight and see what happens. Poor ground path is all i haven't completely eliminated.
I had an old pickup that intermittently gave me a no start because of that. I'd cleaned the mount some, but not well enough apparently. Finally I saw it it throw a huge arc flash between the bracket and fender while starting. after that I ground down the fender under it to bare metal and coated bracket and fender in dielectric grease. That solved it.
Dusterbd13
4/25/17 5:19 p.m.
In reply to akylekoz:
Its actually an amc with a chevy column, ford drivetrain, and custom wiring harness.
I did not have time to get to the shop after work to test ground. SWMBO needed me home asap.
AngryCorvair
AngryCorvair UltimaDork
4/25/17 6:48 p.m.
Dusterbd13 wrote: I did not have time to get to the shop after work to test ground. SWMBO needed me home asap.
Brown chicken brown cow?
Dusterbd13
4/25/17 6:56 p.m.
Huh?
If thats code for "get home before you are no longer a parent" then yes.
dropstep
dropstep Dork
4/25/17 6:58 p.m.
Dusterbd13 wrote: Huh? If thats code for "get home before you are no longer a parent" then yes.
Pretty sure thats code for making kids.
Dusterbd13
4/25/17 6:59 p.m.
Ah. Yeah, i wish it was that call!!!
Would have been a lot more pleasant evening....
AngryCorvair
4/25/17 8:09 p.m.
Brown chicken brown cow is a bedtime story alright.
Dusterbd13
Dusterbd13 MegaDork
10/7/18 8:45 a.m.
My solution for the final picks for this was to run a 12 gauge wire directly from the mounting lug of the solenoid to the negative battery post. Worked flawlessly ever since.
qCcVgWiNiIFRSWBWWzWgDbyxsLzMQl2rTHJ9iLnSptez920ilTFRT84uSN2xWNWe
