NOHOME MegaDork
1/19/25 5:40 p.m.
Are these headers cast or some other form of manufacture? The rim along the edge makes it look like a sheet-metal clam.
PMRacing
PMRacing UltraDork
1/19/25 5:42 p.m.
I think it's a sheet metal heat shield formed over tubular headers.
Mr_Asa
Mr_Asa MegaDork
1/19/25 6:19 p.m.
In reply to PMRacing :
I am inclined to agree, but there is a slim possibility it could be SLS 3D printed sintered metal.  Something about the surface appearance makes me think that for some reason
brandonsmash
brandonsmash HalfDork
1/19/25 7:40 p.m.
I was also thinking sintered, printed 3D metal.
PMRacing
PMRacing UltraDork
1/19/25 7:46 p.m.
If you look at the left side of the picture you can see 4 tubes coming out of the shield (and 2 O2 bungs).  Also there are some screws between the cylinders near the head to hold the halves together.  I could be wrong though.  I didn't go to the original thread....
1/19/25 8:21 p.m.
I'll bet it's a stamped sheetmetal cover. 3D printing makes no sense in a production environment, and even Ferrari production is mass production.
Mr_Asa
Mr_Asa MegaDork
1/19/25 8:49 p.m.
I wonder what the material is.
OzRaceFan
OzRaceFan New Reader
1/19/25 9:15 p.m.
adam525i
adam525i SuperDork
1/19/25 10:39 p.m.
Keep in mind that is an F40 Engine so 3D printing was not an option back when it was produced.
Trent
Trent UltimaDork
1/20/25 10:26 a.m.
It is a heat shield. This giveaway is the rivets holding the two halves to each other
NOHOME MegaDork
1/20/25 10:40 a.m.
Thank you GRM.
Nice piece of stamping I must say,
NOHOME MegaDork
1/20/25 10:46 a.m.
Thank you GRM.
OzRaceFan
1/21/25 2:26 a.m.
.... prolly retaining heat to make the catalytic converter light off quicker to meet emissions test. Or shielding other components ...
iansane
iansane SuperDork
1/21/25 11:31 a.m.
The guy I rent shop space with has an F355 that has a similar design. They're tubular headers with heat shields. Evidently the problem is the headers deteriorate and the engine sucks material back into the cylinders and destroys valves. Enough of a problem that 'rebuilding' your headers is standard practice.
alfadriver
alfadriver MegaDork
1/21/25 11:40 a.m.
It's to keep other things cool. Doesn't change cat light off at all. We tried some super high tech dual wall headers, but switched back to cast iron with better flow.
As for making these at home, seems that one can print a mold and then form around it. It would be a lot of high density plastic, but it's possible.
pq5wYak7gLrOcR6KBj9QSZXqF1FHeq1T2ANI00tp2Pxx7QHhWRTpjc6N19I2W7WL
