Vajingo
Vajingo Reader
11/23/20 5:08 p.m.
So I know what toe out does at the front and the back. And I know what toe in at the rear does for straight line stability. But what does toe In do for the front? Does it provide less turn in for a car that is too snappy?
Toyman01 (Moderately Supportive Dude)
Toyman01 (Moderately Supportive Dude) MegaDork
11/23/20 6:11 p.m.
Zero toe in makes for a twitchy car under hard braking. That's all I got.
wvumtnbkr
wvumtnbkr PowerDork
11/23/20 6:18 p.m.
It'll wear out your front tires...
What the issue you are trying to solve?
Twitchiness can be from caster, too much camber, or excessive front toe out.
11/23/20 7:06 p.m.
Front toe can do really odd things to your steering feel. A slight bit of toe helps with stability, but overall it's a good way to wear tires as wvumtnbkr says. There have been a couple of times where I've been trying to hunt down a steering feel problem and it's been toe. Too many times...
SkinnyG (Forum Supporter)
SkinnyG (Forum Supporter) UberDork
11/23/20 8:38 p.m.
I like too much toe out - neither wheel knows where the heck it's going.  Some say it's "twitchy."
frenchyd
frenchyd PowerDork
11/23/20 8:39 p.m.
In reply to Keith Tanner :
It really depends on the car and the track.  Some cars need that tow in to help corner entry. Some cars require toe out. Some are better with zero.
Some tracks reward toe, either in or out. Corner entry on tracks with camber are rewarded by toe in and punished by off camber.
The trick is to figure out which reward is greater and which rewards are greatest at that track.  Some cars are easily adaptable, some are not.  But realize that toe isn't your only tool. You can balance toe with tire diameter,  pressure. Swaybar rate, Spring rate, camber, caster, shock absorber join everyone, rebound, etc.
That's just the start.
Working with all of the above can make a car dance the Hootie Cootchie. Or go around the track in record time.
Vajingo
Vajingo Reader
11/23/20 8:52 p.m.
Well I'm not trying to solve any car issue, just curious. I think there's a well known Miata alignment which calls for toe in at the front. Just wondering why. I could see it mitigating that short wheelbase entry lift oversteer though.
11/23/20 9:15 p.m.
Pretty much every Miata alignment other than OMGcones!!! has a small bit of toe-in up front. A small bit makes a big difference, though.
frenchyd
frenchyd PowerDork
11/23/20 9:26 p.m.
In reply to Vajingo :
Good, you understand that one item may achieve one portion of the track. You can gain enough on other issues that toe becomes a tiny portion of how  to set up for a given track.
I don't mean to say you can ignore toe. But a trade off between other considerations.
boxedfox (Forum Supporter)
boxedfox (Forum Supporter) Reader
11/23/20 9:32 p.m.
I've had the same exact experience.
The factory service manuals on a lot of older cars recommend a small amount of toe-in, and some alignment techs take that as an invitation to confirm the Illuminati with the front wheels. All it does is make for added wear and weird feeling steering on track.
Donebrokeit
Donebrokeit UltraDork
11/23/20 9:43 p.m.
What about SAI and total toe? If either of these two are janky the car will handle like crap.
But as to toe in, it will help keep the car going straight on rutted roads and can help " turn in" feel.
Vigo (Forum Supporter)
Vigo (Forum Supporter) MegaDork
11/24/20 10:57 a.m.
My basic understanding of why front toe-in exists at all is because when you slam on the brakes, you get a pretty large amount of control arm bushing deflection which changes the toe angle towards toe out (or at least could, depending on the setup). If you start at zero toe and then go significantly toe-out under panic braking, the car becomes twitchy under hard braking. It also makes the steering less sensitive around the center when you're not braking, which makes the car 'easier to go straight in' (i.e. requiring 10% less attention and causing 1% less long-term driver fatigue, marginal).
So, stock front toe-in angle essentially mainly exists to make the car safer for normal street use by barely-trained drivers. I wouldn't say every enthusiast-owned car should have zero front toe or toe out, but i WOULD say that if you can cheaply try alignment adjustments and pay close enough attention to the results you could home in on the right setting for YOU as an enthusiast driver.
I have access to an alignment machine at least 9 months out of the year and i still don't experiment with it that much. Most of my 'for fun' changes have been to observe the differences of caster on steering and ride quality, and i still consider myself as having an only partial understanding of it.
Tom1200
Tom1200 Dork
11/24/20 12:56 p.m.
On the F500 I run 3/16ths toe out for autocross and 3/32nds toe in for road racing. The difference from behind the wheel is even bigger than those number suggest. The autocross set-up would be near undriveable in high speed sweepers, the road race set up makes the car understeer in autocross hairpins. The  reason for the toe out at autocross is due to the solid rear axle (no diff), if the car actually had a diff I'd run a lot less toe out at autocross.
For the Datsun I run the same set up for autocross and road racing 3/16ths toe in as per the Nissan Competition Suspension Manual.
Vajingo
Vajingo Reader
11/24/20 1:56 p.m.
This has been very educational and interesting. I think I will start with zero toe and see how that plays.
11/24/20 2:01 p.m.
If you watched Bargain Racement from the Bad Obsession guys, they ran zero toe. It made corner entry a little exciting but gave them noreable straight line speed over some of the other cars.
bobzilla
bobzilla MegaDork
11/24/20 2:14 p.m.
In reply to Toyman01 (Moderately Supportive Dude) :
I've always ran zero toe with no drama on my macstrut FWD cars. Auto-x I ran 1/8" toe out for turn in.
buzzboy
buzzboy Dork
11/24/20 3:17 p.m.
My racecar is aligned toed in, 1/8" if I recall. Due to a screw up(who me?) installing new tie rods I got to race once with toe out instead. Toeing out gave me much better turn in which is lovely in a heavy understeery car but it didn't like going in a straight line. Also toed out it wore tires much worse.
frenchyd
frenchyd PowerDork
11/24/20 3:48 p.m.
Do you scale your car?  I have a cheap bathroom scale lever arrangement. And using it I can make a car do completely different things. Do you measure your tires?  If so put 10 extra pounds of air in one and see what happens to the circumference.  Now put it on a scale. ( yes I know they have affordable electronic ones now)
      Toe is only a tiny portion of making a car do what you want it to and it's affected by things like camber ( in the race track ). Camber on the car. Caster, air pressure, tire temps etc.
I like Torsion bar suspension because it's so easy to change spring rates and ride heights. But you can shim springs as well. Just more work. Or make a screw adjustable platform like the NASCAR guys do.
      Then you'll figure out what a tight radius corner calls for. A wide radius corner. Banked corner, flat corner. Etc. Once you've listed all the corners. Figure out what is called for? Corner entry? Corner exit? Transition?
Get some old geezer who was fast in his day and did his own work to talk you through the lap.
iceracer
iceracer MegaDork
11/24/20 5:32 p.m.
Toe in is to make up for the "play" in the steering linkage.
o2CfIgutWV37sCwE5sgy6TkyPdl9HF2K9KmNMzRFSrX1iak566ZgyJiP0f5ld9xc
