Brian
UltraDork
1/29/20 7:49 p.m.
2 stories.
1. about a year and a half ago, the gas tank fell out of our 00 maxima breaking the sending unit. We replaced the sending unit and plactic lines plus a new o-ring. Since then you can't fill the tank normally, you have to basically trickle gas in (20-30 minutes to fill the tank).
2. 01 Yukon XL 2500 is doing the same thing, but we just got it and don't know it's history at all.
we had a similar issue on a 92 Civic VX that we fixed by running a new vent hose (sorry forget the exact details on this one)
I'm thinking that on the first 2 I should install some sort of vent valve into the tank that will release pressure when it gets to pressurized.
Anyone have any thoughts or ideas?
I don't want to drop the tank on either vehicle if at all possible. These are rusty chicago vehicles.
Maxima probably has a pinched hose from the tank to the evap cannister, or a hose routed wrong. Drop the tank again after you find a hose routing diagram.
The Yukon has a bunch of dust in the vent solenoid filter, or maybe in the cannister. Won't have to drop the tank on it.
Brian
UltraDork
1/29/20 8:18 p.m.
we'll check the Yukon. the maxima we already did check about 7 months ago and everything looked normal. Dropping that tank isn't likely going to happen again. too much of a time consumer.
Early S197 mustang's had a recall for a similar problem that was related to blocked vent hoses on the gas tank. Sounds like you're on the right path.
