glueguy
glueguy HalfDork
12/19/16 3:56 p.m.
First and second act fine, when it shifts into third motor revs and it doesn't propel. If I keep the lever in 2 it drives fine, just limited to about 40mph. Is there any band-aid beyond a new trans?
Ranger50
Ranger50 UltimaDork
12/19/16 4:27 p.m.
No.
Bobzilla
Bobzilla UltimaDork
12/19/16 4:30 p.m.
Well, there is one thing. A used trans.
NEALSMO
NEALSMO UltraDork
12/19/16 4:30 p.m.
My 700r4 use to do the same thing. I could usually get it to upshift when cold...sometimes. Just about everything I found online that caused the problem required a rebuild. I opted for a $400 rebuilt unit from craigslist.
Knurled
Knurled MegaDork
12/19/16 4:37 p.m.
I'm shocked nobody has mentioned a tow dolly yet.
BrokenYugo
BrokenYugo MegaDork
12/19/16 5:57 p.m.
Remove transmission, install rebuilt transmission and a cooler to extend lifespan of the rebuilt trans.
gearheadmb
gearheadmb Dork
12/19/16 6:54 p.m.
Knurled wrote: I'm shocked nobody has mentioned a tow dolly yet.
I was going to suggest gravity.
gearheadmb
gearheadmb Dork
12/19/16 6:54 p.m.
Or drive backwards
Knurled
Knurled MegaDork
12/19/16 7:02 p.m.
gearheadmb wrote: Or drive backwards
It's not a Ferrari.
(or an MG dressed up to look like one)
MattW
MattW New Reader
12/19/16 7:20 p.m.
Isn't there a transmission additive that supposedly does the trick for a while? Lucas?
Worth a shot, the transmissision is dead anyways at this point.
Donebrokeit
Donebrokeit Dork
12/19/16 7:26 p.m.
Back roads. I did that for three weeks till I found a replacement trans.
former520
former520 Reader
12/19/16 7:32 p.m.
I can tell you that when it happens just outside of KC in Missouri, it will make it back to MN in 2nd gear. It will take you longer and it will do it while towing a race car, trailer, 6 guys (conversion van) and all your tools.
When you got to get back for work Mon morning, you got to make it back. Transmission was still rebuild-able afterwards, twice!
Knurled
Knurled MegaDork
12/19/16 7:38 p.m.
former520 wrote: I can tell you that when it happens just outside of KC in Missouri, it will make it back to MN in 2nd gear. It will take you longer and it will do it while towing a race car, trailer, 6 guys (conversion van) and all your tools. When you got to get back for work Mon morning, you got to make it back. Transmission was still rebuild-able afterwards, twice!
That beats a service manager's Bronco (think OJ) that made it back to Cleveland from the wilds of Michigan with no rear driveshaft after it blew out. And blown head gaskets, in the dumping coolant into the oil way. He needed it floored in 2nd gear to maintain 55mph.
I've had some long ass "will I make it?" drives but that beats all of them.
Gearheadotaku
Gearheadotaku PowerDork
12/19/16 8:15 p.m.
I've added brakefluid to slipping transmissions, worked for a short time (which was all I was expecting)
RealMiniParker
RealMiniParker UberDork
12/19/16 8:43 p.m.
MattW wrote: Isn't there a transmission additive that supposedly does the trick for a while? Lucas? Worth a shot, the transmissision is dead anyways at this point.
Speaking from experience with a 3rd-4th slipping 4L60E, yeah, there are snake oil treatments. They don't work.
KyAllroad
KyAllroad UberDork
12/19/16 10:39 p.m.
Is the fluid burned? If it's just revving in 3rd then the fluid should burn and be stinky pretty quick. Isn't there some solenoid or some such that controls the 3-4 gears and would prevent the tranny from pulling?
bearmtnmartin
bearmtnmartin Dork
12/20/16 12:16 a.m.
Sawdust.
12/20/16 12:18 a.m.
Most 4L60s I've seen E36 M3 the bed around 120,000-140,000 miles.
edizzle89
edizzle89 Dork
12/20/16 7:49 a.m.
bearmtnmartin wrote: Sawdust.
came here to say this, its the classic 'fix-all' for any auto trans
TU44Bt0Fw47tb9uvZ7BzM2RWdNG16SFIrf362qWDV08mkl9ur9vIZaU87D7cc1hX
