I am looking for a throttle position sensor pigtail/harness repair. The sensor in question is from a 2007 Arctic Cat M1000 EFI snowmobile.
Looks to be a 4 wire connector.
Thus far I have found only new and used complete sled harnesses, no pigtails.
Sled salvage yard, or if you have the plastic part still probably get the pins for something like this and repin the original plastic.
Do you see it here?
Maybe P52-D1 in the 5th set of pictures, top right?
Opti
Dork
5/21/20 12:48 p.m.
Opti said:
Would this work
https://www.amazon.com/Connector-2JZ-GE-Throttle-Position-Sensor/dp/B07SQS8BXC
Holy crap dude!
what is odd is that the injectors for this throttle body setup cross over to 2jz as well, I guess it shouldn't surprise me the tps did too.
Just a update to verify that Opti did indeed have it bang on. 2JZ tps is the answer here.
Note the SU mounting base I have installed on this snowmobile tbi unit. You can guess what I am up to.
putting SU's on your sled, no doubt.
