That he had someone tell him that
he was saying something about placing a glass of water
on the radiator cover
and adjust the timing
and watch the water levels
of the glass i placed on there
^^^ Actual cut/paste from the IM convo about his truck. No bull E36 M3! I'm calling BS on this one. anyone else heard this one?
yea, that's old school so I'm told, never tried it, still trust my timing light.
tuna55
PowerDork
7/12/13 10:23 a.m.
He's, I think, trying to make it smooth out by looking at ripples? I guess it's not the most idiotic way I've heard.
I guess... maybe back in the magneto days? dunno
50s hot rodding, kinda makes sense, not calling BS here
I heard that story from enough old timers
one way to bust the myth, water glass and verify w/ timing light, go for it
Used pro grade dial back lights are cheap.
If you're tuning a flathead in 1955...sure, makes since.
I don't know........ I'm not the oldest olde school guy here... but setting timing by ear and feel......
Its one thing to set a VWs (air cooled) points with a match book cover.... but when it comes to timing.... I've always used a light
jstand
Reader
7/12/13 10:57 a.m.
I would guess you advance timing until the water starts to get rough and then turn it back until a regular pattern is present.
The water might pick up the vibration from knocking before you can hear it, but defintely not as accuraet as a timing light.
Similar to using a Sirometer to set engine RPM.
ransom
UltraDork
7/12/13 10:58 a.m.
I bet you could do worse, but I also think this is one of those things from automobilia wherein there's a "gut rightness" to the idea that doesn't necessarily align with what the engine really wants.
Certainly nowhere near as bad as the customer who's always telling me we should put mothballs in the tank of our race cars.
ransom
UltraDork
7/12/13 11:05 a.m.
In reply to poopshovel:
Is there any rationale handed down along with that pearl of wisdom, or is it just the done thing?
Back in highschool auto shop, being able to balance a nickel on the air cleaner was worth extra credit. My buddy could balance a dime in his.
STP fuel system cleaner is naphtha (mothballs) dissolved in kerosene, according to the MSD sheet.
The timing method assumes that the distributor has an advance curve that is calibrated for both the smoothest idle and best power at high RPM. If it was calibrated for lowest emissions at idle, all bets are off...
Wonder also if this is a variant on admiring how smooth an inline 6 runs when tuned right. There used to be various claims of being able to stand a nickel on edge on the air filter, and about a full glass of water not spilling a drop.
Waitaminit now... it might have some input on setting initial timing but prolly used more for setting idle mixture/ speed... keepin' it smooth ya know.
I suppose that could help you get the idle trims balanced on a V8.
I use a vacuum gauge when timing something that has goofy or hard to read marks.
i use a silver sharpie to make marks where they are easier to read..
In reply to novaderrik:
White grease/paint crayon, rub it in the marks, wipe off with rag, boom, white timing marks. Cheaper than a sharpie and has a shelf life of about 10000 years, lives right next to the timing light in the tune up tool kit.
Woody
MegaDork
7/15/13 11:10 a.m.
I place a can of beer on the fender and adjust it until it sounds good enough.
Sometimes, it takes a bunch of beers.
I use this method as well.
I work my magic, and adjust on it 'til it backfires thru the carburetor and fully singes my eyebrows and beard, then back off it off 1/10 turn.
That's like how they used to tune MR2 turbos: Crank up the boost, crank up the fuel to pig rich. Then start leaning it out until a chunk of one of the pistons goes out the exhaust port. Rich it up one notch and you're there.
