Jaxmadine
Jaxmadine HalfDork
11/17/13 1:22 p.m.
Apparently no one knows what im talking about on the miata forums. Anyone here done it?
Im a bit concerned since the shafts break or something like that, so I hear.
EvanB
EvanB PowerDork
11/17/13 1:40 p.m.
I don't know what you are talking about either.
ditchdigger
ditchdigger SuperDork
11/17/13 1:43 p.m.
This?
to
I have heard it makes a difference in CFM but I would love to see some hard data on power improvements.
Sil80redtop
Sil80redtop Reader
11/17/13 1:47 p.m.
Interesting.
ShadowSix
ShadowSix Dork
11/17/13 1:47 p.m.
Yeah, I've heard of it with Fox Bodies, but was always skeptical whether it really made any difference...
Where do Miata throttle shafts break? I doubt the weak part is the part you'd be cutting on.
Jaxmadine
Jaxmadine HalfDork
11/17/13 2:13 p.m.
Yes ditch. That. Good for 1-2 whp on a neon. Lots of info on it on neons.org. its like going 2mm bigger on the throttlebody.
Supposidly the screws break off or something? But mainly on race cars. Not entirely sure. Im about ready to just ignore the internet and build it like I would any other car.
SnowMongoose
SnowMongoose HalfDork
11/17/13 2:20 p.m.
Is the difference/result in the 'broken' third image?
ShadowSix
ShadowSix Dork
11/17/13 3:15 p.m.
In reply to Jaxmadine:
Hell, replace the screws while you're at it. I'm sure it'll be fine.
Is the Miata TB something of a bottleneck? I am vaguely remembering that the TB in the fox body 5.0s was considered a bit of a bottleneck and this was on the list of "free" ways to fix it.
Jaxmadine
Jaxmadine HalfDork
11/17/13 4:28 p.m.
Not sure. The intake is one for sure tho.
Anything that helps it breath cant be a bad thing.
noddaz
noddaz Dork
11/17/13 6:08 p.m.
One would think you could almost achieve the same thing by smoothing out the ridge at A or B. But that does not answer the OPs question, does it?
noddaz
noddaz Dork
11/17/13 6:20 p.m.
And me thinks the OP meant this, which is on a Honda BTW. Original: Modified:
Jaxmadine
Jaxmadine HalfDork
11/17/13 6:23 p.m.
I have pics for days. Just not sure if anyone has done it to a miata. Guess ill be the first again.
stafford1500
stafford1500 Reader
11/18/13 7:39 a.m.
The thing to be wary of by thinning the center of the shaft is not so much full throttle, but closed throttle at high revs. The shaft provides a fair bit of bending resistance to all the suction form the motor side. With a thinner shaft, the bending is carried more by the throttle plate and may cause the throttle plate to deflect and dig into the side of the throttle body bore. This could cause sticky throttle response going back to the gas.
I have seen this on throttle blades that were machined with no shaft thickness across the plate and the shafts only being supported in the throttle body housing. It was not good for driver feedback when the throttle had to be pushed harder to get it open when they were trying to feed in throttle slowly on corner exit.
N Sperlo
N Sperlo MegaDork
11/18/13 7:44 a.m.
If someone wanted to halfshaft my throttlebody, I'd be rather concerned.
spitfirebill
spitfirebill UberDork
11/18/13 7:59 a.m.
Crikey, they been doing this on SU carbs for years.
SlickDizzy
SlickDizzy UberDork
11/18/13 8:43 a.m.
I believe the correct term for this is "throttle blade machining," as a "halfshafted throttle body" raises images of a CV halfshaft stuffed into a TB. I was confused as hell when I read the thread title.
DeadSkunk
DeadSkunk SuperDork
11/18/13 9:10 a.m.
spitfirebill wrote: Crikey, they been doing this on SU carbs for years.
I did this to a dual carbed Mini , about a hundred years ago. It's been a standard modification to SU carbs forever
wspohn
wspohn Reader
11/18/13 10:22 a.m.
If any bottlenecking in the intake is downstream of the TB, you won't see much improvement there. If the TB is well sized to the engine, i.e. it will flow way more air than the engine can possibly use, then ditto.
Have to check with a Miata engine specialist to know. MG people have been doing this for years even though it doesn't really get you much.
BoxheadTim
BoxheadTim PowerDork
11/18/13 10:29 a.m.
It's not an uncommon mod on DSMs as well but I'm not sure if it's going to make a big difference on a Miata. ISTR that especially on an NA, breathing mods that are external to the engine don't do that much for performance, if anything. I've also never heard that the TB is that much of a bottleneck at WOT on an NA, at least when we're talking mostly stock engine. Once we're talking an engine with either a later head or a gasflowed head things might change somewhat.
RealMiniDriver
RealMiniDriver UltraDork
11/18/13 11:42 a.m.
I did it, too.
Jaxmadine
Jaxmadine HalfDork
11/18/13 2:22 p.m.
Its a 99. And apparently the shafts tend to crack a bit. So ill just leave it be.
Main thing ive noticed when doing the mod tho is partial throttle gains. Theres no more hump when you cut the shaft off.
And yes. I do it to su carbs as well.
dean1484
dean1484 PowerDork
11/18/13 2:37 p.m.
I would be carful doing that. You can do some significant porting to the "barn door" style AFM that will improve things. I did this to my RX7 and it made significant improvements.
BoxheadTim
11/18/13 2:38 p.m.
If it's a 99, it shouldn't have a barn door AFM...
Eb3hKCwDUrSnKA7qpBYGpnVCybWoChVpZt2WspJ7kDiYr3KnpVbhqwnBVa3Omlt3
