xflowgolf
xflowgolf Dork
6/10/17 1:04 p.m.
So I drove my mk1 diesel away from home. Maiden voyage. Battery is completely dead.
This car has a hacked minimal harness to make it run, no factory wiring, and no factory cluster. The alternator does not self excite, which I found out the hard way.
How can I rig this up to get home?
Can I put 12V jumper right to B+?
Do I just tap it then remove it?
Etc.
Thanks!
xflowgolf
xflowgolf Dork
6/10/17 2:32 p.m.
Nobody?
JeffHarbert
JeffHarbert HalfDork
6/10/17 3:51 p.m.
IIRC, factory wiring has an idiot light between switched 12v hot and the D+ terminal, which is what excites the alternator.
xflowgolf
xflowgolf Dork
6/10/17 4:19 p.m.
Well, finally got it jump started. Turns out, tapping 12V to the D+ terminal once it was running kicked in the alternator to charge. So far so good.
jimbbski
jimbbski Dork
6/12/17 9:15 p.m.
I installed a 12v light bulb in line with the exciter wire. On mine there was a small gauge blue wire that was routed to the dash and then to the ignition switch. It developed a dead lead somewhere so I rewired it and installed a 12V bulb to put a load on the alt. Problem solved!
Q4v6kLlCGm6Z30Uk1Wyzo7d2Ya0dcSiLEuYhSTUzOqU4F61ruoCZ4dfiPtuaQ2SY
