So thinking more while I couldn't sleep, I had a brainstorm. Could I use allthread, washers and nuts into the body mount plates to lift the whole body a few inches to make everything easier and also negate the need to drain and pull the trans to seal the seam above it? This would also mwke running the return line and drilling for the seat belt mounts out much easier. I cant believe that i forfot to drill the 8 holes for the seat and belts before I aelded in the floor...
