manladypig
manladypig New Reader
6/17/19 11:10 p.m.
So I'm redesigning almost my whole subframe to mount a 13b Rensis in my 1976 fiat 124, and I need some engine mounts to complete the union. I'm looking for something like this:
so, a cylindrical style mount with simple studs top and bottom. I'm looking for poly mounts. These ^^ are from a c5 corvette but they are a little too big (3") and pricey (190$) Does anybody know of other cars with engine mounts of this style? My stock fiat engine mounts are like this but there are no poly mounts on the market so I have to look elsewhere.
ShawnG
ShawnG PowerDork
6/18/19 12:02 a.m.
Ford flathead motor mounts.
They're not studs top and bottom but they're a stackable rubber donut sandwich with a thru-bolt. We use them to build custom mounts fairly often.
Cheap too at around $20.00 each.
Stefan
Stefan MegaDork
6/18/19 12:14 a.m.
Or a couple of hockey pucks, big washers, bumper bolts and a welder.
TurnerX19
TurnerX19 HalfDork
6/18/19 7:36 a.m.
Skip the poly. Go to McMaster Carr and look through their selection of anti vibration mounts for machinery. Many cylindrical shapes in various durometers, including the exact replacements for Lotus 7/ Caterhamsurprise
Streetwiseguy
Streetwiseguy MegaDork
6/18/19 7:40 a.m.
140 Volvo has studs centered, 240 has them offset a bit.
rslifkin
rslifkin UltraDork
6/18/19 7:41 a.m.
Check BMW E38 / E39 transmission mounts.  They look a lot like that, just not as tall.  They're also really cheap.
kevinatfms
kevinatfms Reader
6/18/19 8:43 a.m.
This. You can turn down a hockey puck on a lathe pretty easily. Drill your center hole and bolt through.
SkinnyG
SkinnyG UltraDork
6/18/19 9:50 a.m.
I thought they used old Jag mounts?  Two-bolt flange on the bottom, threaded hole on the top.
Or would this be the more modern ones??
wvumtnbkr
wvumtnbkr UberDork
6/18/19 10:39 a.m.
I mounted my 3400 v6 in my rx7 with hockey pucks.  Works just fine.
TurnerX19
TurnerX19 HalfDork
6/18/19 10:49 a.m.
In reply to SkinnyG :
Your description is accurate. Probably are the same. I would use the hard ones on a Jag, and the softest on a bike build. I did use the middle ones on a Kent engined Caterham. Also look a lot like MG TC, but have incorrect threaded hole.
Hoondavan
Hoondavan Reader
6/18/19 10:51 a.m.
E30 M20 mounts look lik they're straight-thru (not offset).  Check out Condor Speed Shop
I used Delrin Concor mounts on my M42 (E30 4cyl) until I realized there was waaaaayyyy too much NVH (that took about 30 seconds).
68TR250
68TR250 Reader
6/18/19 11:00 a.m.
1973-1976 TR6 gearbox mount?  TRF has them for$ 5.99. Part number is 150403
jimbbski
jimbbski SuperDork
6/18/19 12:11 p.m.
https://www.rockauto.com/en/moreinfo.php?pk=227822&cc=1196153&jsn=403
This is a motor mount for a 1973 Mercury Capri.
It's rubber so it's an alternative to any other mounts you may consider.
Nou3DA0iKZp4ymrSNNP8irRlJTlbiHskpLvqH9AK52LbVfeKlsDIoIuSxmnvwR0W
