jonnyd330
jonnyd330 Reader
12/16/24 9:27 p.m.
I bought an S2000 that was setup for HPDE but it had some old seats and an old 4 pt harness. I ordered a new OMP seat and Gforce 6pt harness but I am not sure where to attach the lap belt.
I have a PCI Seat Mount (link) with a sub belt bracket and a roll bar for the shoulder belts.
The lap belt is where I am not sure what to do, the left side oem belt mounting location works with the eyebolt but it is blocked by the seat mount and the other side does not have anywhere to mount too. Curious if anyone has guidance on the best mounting places.
Below are pictures of the floor. I put an arrow where the 1 oem belt mount is. I'm not sure what to do with that side because it hits the seat mount and the other side has no where to install an eye bolt.
Spearfishin
Spearfishin HalfDork
12/17/24 7:04 a.m.
Through the floor pan with backing plates? Not sure what obstacles that presents, but for the whopping 4 or so harnesses I've installed, that's how most of the lap belt anchors were installed.
jfryjfry
jfryjfry UltraDork
12/17/24 11:37 a.m.
Contact pci and see what they say.  I've seen many brackets that incorporate the lap belt mounts on the bracket itself.
otherwise don't be afraid to punch some holes in the floor and install a pair of eyebolts with backing plates (eyebolts often come with large washers for this purpose).
APEowner
APEowner UltraDork
12/17/24 12:16 p.m.
For the side that has a factory mounting hole you a bolt in rather than clip in bracket should solve your problem. Depending on what belts you bought you may be able to change it.  Others are sewn in and can't be changed.  For the other side you need to drill a hole and either bolt the belt bracket in or install an eyebolt and use the clip style bracket.  Either will need a backing plate.
jonnyd330
jonnyd330 Reader
12/17/24 3:31 p.m.
In reply to APEowner :
Thank you, I didn't think about using a bolt in bracket.
c4LAsHmjUGCIMXjLEwsOzQTfF3dUPq7bOV4Xwh18k0ixCdcfAY7buRrSwZYJUAgi
