Hoppps
Hoppps Reader
9/1/24 11:19 p.m.
I'm trying to make sure I found full time power for aftermarket gauges in a 94 Miata.
I tapped into the blue/red but trying to make sure it's actually full hot. When I have the multimeter hooked up with the car off and batter connected, it's showing negative volts. If I turn the key on it's positive.
my thinking is that it should always show positive volts regardless of key position...but I am an electrical noob. Help please??
ShawnG
ShawnG MegaDork
9/1/24 11:24 p.m.
Use a test light.
It's showing negative volts because it's showing the load from the devices attached to the circuit.
MadScientistMatt
MadScientistMatt UltimaDork
9/2/24 11:15 a.m.
Just how many negative volts do you measure, and what point are you using for ground?
g9Vw5l439Z7Uv3cmVeE0HSpAqer0CohmeHsnyxct6Mqh79yTNRBilybghTo6dK1f
