jmhonnold
jmhonnold New Reader
5/7/12 3:16 p.m.
Hi Guys,
I have a 1990 CRX Si that I am finally getting back on the road after an engine transplant.  I was running the stock rim/tire (185/60HR14) before the transplant, but since I have bigger brakes I need to update the rims/tires.  Since this will be mostly a daily driver, I am leaning on the conservative side and thinking about a simple +1 upgrade to 15" rims and 195/50 tires.  The problem I have is that it is hard to find 15" rims that have a width smaller than 7".  195/50 tires seem a little narrow for a 7" rim.  Since the CRX does not have power steering I am worried about going larger than 195, but I realize that this may be necessary.  So, is a 7" rim o.k. to use with 195/50 tires?  If not, would the drivability suffer with 205/50 tires?  I don't really want to go to a 16" rim since they are quite a bit heavier.  The 15" rims I am looking at are around 14.5 lbs and the 16" version of that same rim are more than 3 lbs heavier.  I really appreciate any help you can offer.
John
MG Bryan
MG Bryan SuperDork
5/7/12 3:18 p.m.
The formatting berkeleyed up your post.
jmhonnold
5/7/12 3:21 p.m.
Please see my other post. The formatting did not work correctly on this post. Sorry.
qVZQrL3ZdOK2ipiVR6vtdLknSiR6N9eczrwKTGN0SXGlAQfuxy0ZtEJCyj92vFoQ
