sethmeister4
sethmeister4 Dork
11/5/14 12:51 a.m.
Anyone have any experience with these? I'm wondering if anything from a TSX, Accord, or maybe even an RDX with the K23T will bolt onto my '03 CR-V. Larger throttle body? Bigger Injectors? Better flowing manifolds? I know these motors are great, but it is still underpowered in the CR-V. A few basic bolt ons and a good tune (a buddy already told me he could do this) and maybe it will have a little better power and MPG. Might be a waste of time and $, I dunno...just a thought.
Swank Force One
Swank Force One MegaDork
11/5/14 10:07 a.m.
You don't need bigger injectors unless you have more flow.
One of the pimpy "real" vtec heads should bolt on, but then you're opening a big can of worms.
captdownshift
captdownshift Dork
11/5/14 10:10 a.m.
hondata reflash and cams, nothing in terms of factory bone yard goodness on the cheap though
lnlds
lnlds Reader
11/5/14 2:29 p.m.
The accord guys bolt on the TSX in and supposedly get more midrange from it but not sure if it'll bolt in cleanly to a cr-v.
This is the write-up for accords http://www.driveaccord.net/forums/attachment.php?attachmentid=6665&d=1165213978
The Canadian
The Canadian New Reader
11/5/14 5:19 p.m.
with work. most will fit it just depends on how much work you want to put into it.
sethmeister4
sethmeister4 Dork
11/6/14 12:33 p.m.
In reply to Swank Force One:
I was thinking larger throttle body, more flow, slightly bigger injectors, etc. The TSX makes significantly more power than the CR-V, but most of that is probably from the difference in compression ratio and general tuning, I would assume, not the "bolt on" stuff. I wonder what the RSX and TSX guys do for bolt ons?
SlickDizzy
SlickDizzy PowerDork
11/6/14 12:41 p.m.
In reply to sethmeister4:
A little Googling on the RSX shows that CAI gets ~5HP, headers ~10HP, Hondata tune ~10HP, and from there it gets into cams, test pipes, forced induction, and rare JDM goodies...doesn't sound like much is junkyardable.
cKXuHvHml1LqPj0T9ZLLUA1eVfE2NB0NCNObqjPplRySfKbhLEO3dU1SwijVigxa
