cutter67
cutter67 Reader
2/15/13 5:47 a.m.
i have decided on buying a hotwater pressure washer or a steam jenny and cant decide on what to buy. the biggest thing is pricing...it's all over the board and everyone offers them i would like to stay in the $2,500.00 to $3,000.00 range unless someone knowns of one cheaper that is good. Northern Equipment seems to have some at a nice price. i would prefer 120v but i think i will have to go 230v which isnt a problem at garage.
what i am really looking for is information on what to look for in the way its constructed and what to stay away from in the way it's constructed
aussiesmg
aussiesmg UltimaDork
2/15/13 6:31 a.m.
Go to CPO outlets, they sell a lot of rebuilt units that were warranty returns and have Karcher as a supplier, I got mine from their and its been great, maybe 60% of retail price.
http://www.cpooutlets.com/shop-our-outlets/shop-our-outlets,default,pg.html
foxtrapper
foxtrapper PowerDork
2/15/13 6:55 a.m.
cutter67 wrote: i have decided on buying a hotwater pressure washer or a steam jenny and cant decide on what to buy.
You do understand that those are two completely different things, right?
A true steam cleaner, which Jenny does make, is a real steam pressure vessel, and is built accordingly. It is not a device you want to have rupture, so the price reflects the build requirements. A hot water pressure cleaner is nowhere near as exciting when it breaks.
I've used both, and for serious cleaning, a high pressure steam cleaner wins. They also do a whole lot more damage if you're not carefull. Which considering the damage you can do with any high pressure washer, is saying something.
cutter67
cutter67 Reader
2/15/13 7:06 a.m.
foxtrapper wrote: You do understand that those are two completely different things, right? A true steam cleaner, which Jenny does make, is a real steam pressure vessel, and is built accordingly. It is not a device you want to have rupture, so the price reflects the build requirements. A hot water pressure cleaner is nowhere near as exciting when it breaks. I've used both, and for serious cleaning, a high pressure steam cleaner wins. They also do a whole lot more damage if you're not carefull. Which considering the damage you can do with any high pressure washer, is saying something.
yes i understand the difference i already have a 5000psi Landa cold water pressure washer which i have sold if i decide to go with a hotwater pressure washer or i will keep if i decide on a jenny. i like buying used construction equipment, backhoes and things like that and hotwater or steam cleans this type of equipment a lot better
foxtrapper
2/15/13 8:50 a.m.
That kind of equipment is what we used the steam Jenny on. It worked quite a bit better than our hot water pressure washer.
I could slice wires and such superbly with either. The steam cleaner was better at ripping the case off of hoses. I think it may have had to do with the heat softening the rubber. Many a radiator or hydraulic hose was promptly down to exposed cords with the steam cleaner.
hnIWxa0DRzrmuRHBHZvodOBuGsKWv5BzzZWH4amKbo4YDbKDq4oWzeEkwWDxOgR4
