DeadSkunk  (Warren)
DeadSkunk (Warren) PowerDork
12/12/20 3:26 p.m.
No photo description available.
So this is an aluminum fender and I haven't bought it yet. It's 0.090 thick aluminum and it's 34 inches long. I'd like to make it more like 28 inches. First thought was to buy a shrinker from the hammer store, but they're only good for 0.050'' thick. Second thought was to wrap it around a tire and wheel combo and reform it with a ratchet strap, but I have to wonder if the edge would kink. The fender is 20" wide and I would cut it down the middle to make a pair of fender extensions/flares for the Challenge Corolla. Any other ideas that I can do in my ill equipped home garage?
12/12/20 3:32 p.m.
Pie cut the lips.
DeadSkunk  (Warren)
12/12/20 3:36 p.m.
In reply to Keith Tanner :
If it were steel , I would do that and MIG it.  Because it's aluminum cutting it isn't going to work because I can't weld it.
Anneal and shrink like in the video below.
Should be able to get you close.
Trent
Trent PowerDork
12/12/20 3:53 p.m.
If you try to bend it to a tighter radius the lip at 90° will bend outwards and be more like 70° when done. I bet you could do a little tuck shrinking on it to do the job.
I will guess that fender is made from a 3000 series alloy which is usually sold and stamped in a half hard condition.  I would anneal the lips before doing anything.  Put a sharpie line on the lip and heat the area with a propane torch until the sharpie fades. Then create the tucks either with pliers, fork or weld a couple of pieces of bar stock 10mm apart and make the tucks with a hammer and chisel. Then work the tucks flat. It really won't take much to change the radius what you need.
Google "tuck shrinking"
I would still give it a go with a Lancaster style shrinker first. That aluminum in a dead soft condition should be fine, even at 0.90" if it fits in between the jaws
NOHOME MegaDork
12/12/20 4:24 p.m.
In reply to Trent :
This was my immediate thought. I have abused the shrinker stretcher a few times and got away with it,
DeadSkunk  (Warren)
12/12/20 4:51 p.m.
I never even thought about annealing it first. That's why I ask questions on this forum before I dive in and ruin stuff.
DeadSkunk  (Warren)
12/12/20 4:56 p.m.
In reply to Trent :
If the edge did move to something less than 90 degrees it might actually look better if I don't put it on the car exactly horizontal, but tipped a little so the bottom edges are a bit closer to the rocker panels .
DeadSkunk  (Warren)
12/12/20 5:06 p.m.
In reply to NOHOME :
Pete, if you have a shrinker could you look at it and see if 0.090 material will go in between the jaws?
RevolverRob
RevolverRob New Reader
12/12/20 5:18 p.m.
Who needs to weld when pop rivets are awesome?
DeadSkunk  (Warren)
12/12/20 6:07 p.m.
In reply to RevolverRob :
While there would be rivets involved, I didn't envision them in the fender flare lips.
iceracer
iceracer MegaDork
12/12/20 6:24 p.m.
Change length from 34" to 28".    Easy, but think this not exactly what you are looking for.
12/12/20 6:49 p.m.
They're a design element if you say they're a design element, damnit!
NOHOME MegaDork
12/12/20 7:15 p.m.
Closest I could find in the offcut pile was 84 thou. I did slide a bunch of paper sheets in to measure 110 thou before it started to get tight.
This is the 84 thou with a few cranks on the shrinker
DeadSkunk  (Warren)
12/12/20 7:33 p.m.
Thank you, Sir.
Sm9y1EXlHVzAJaVZAwTm6HJmtDmUb60R6G8OgP8ZyeFizNVZt7wwQON41AhPvcAz
