Knurled, I've posted the image in my original post down at the bottom of this reply. But with the dimensions I'm working with. See also the attached behind the bumper shot, I've got quite a lot of room to work with and am fairly handy with cutting tools so even more space could be made if desired. I'm currently seeing 30-45 degrees above ambient pending how hot it is outside, cooler track days I'm closer to 30. Hotter days like ATL in August I'm 45 or a bit more.
Jason K,
I'm not currently having issues with the intercooler setup, I'm having issues with the radiator/oil cooler behind the intercooler getting too hot. I measure IAT's and typically hover 30-45 degrees above ambient when I come off the track. Car is used for time trials and lapping days (and hopefully also One Lap of America next year.
I'm not sure which measurements you are after or thinking would help so I re-hosted the original image with dimensions on it. My thought was the current end tanks are blocking a fair bit of the grille opening and preventing some flow to the radiator/oil coolers. A new intercooler setup would hopefully lower IAT's closer to ambient and allow more airflow to the other coolers, win-win?
The car currently has pretty good ducting, I have modified the factory M3 ducting with weather stripping material on both sides and around the intercooler. All surfaces are fully sealed, any air coming through the kidney grilles or the lower grille must flow through the coolers before exiting the engine bay. The only spot I could see where I can practically gain better ducting is by making a chimney type vent out the hood (which would require a different intercooler/radiator setup which is the path I'm heading down)
Here's a picture without the intercooler so you can get an idea of how things are ducted, the kidney grilles are also ducted straight to the radiator.
Since that picture was taken I've also removed the AC Fan and condensor which opened up quite a bit of extra surface area to the radiator.
You both mentioned that the vertical core would be the way to go which is great because that's what I was hoping to do from both a weight savings and shorter path standpoint. Jason do you think in this case the disadvantage of the 90 degree turns would out-weigh the previous pipe layout?
Current pipe layout has the cooled air exit on the passenger side and route back under the engine over to the driver side before coming up into the intake:
The proposed design with a vertical intercooler would look more like:
and dimensions of the current setup:
The grille opening is 7" the current intercooler is 8.5" tall and tipped at an angle to allow most of it to fit in the opening.
So based on all of that, I was leaning towards the Treadstone CV25 intercooler core because it's 25" long, 6" tall, vertical flow and you can buy these pre-made end tanks which seem convenient:
