Travis_K
Travis_K UltraDork
10/8/13 1:05 a.m.
Specifically, are there any other subarus that have a transmission with the same gearing (at least the same final drive) as a 1996 legacy outback 5 speed? The transmission is getting a bit tired with almost 430k miles on it, and hasn't sounded very good for a long time. I have been looking for another 5 speed 96 outback, but since its the only year of legacy outback to come with a cable clutch transmission I dont know if there are any others I could get the transmission from. Maybe an outback sport?
ValuePack
ValuePack SuperDork
10/8/13 1:15 a.m.
Cable clutch AWD trannies date back to '89, so you've got a bit to look around at. I assume it's a 4.11FD(read the rear diff)? Find another 4.11 cable trans and pop it in, don't limit yourself to just the Outback. 1st gen Legacy and early Impreza 1.8 and 2.2 are potential donors. Can't remember when cable went the way of the dodo, but a coworker's '99 Leg Brighton was cable.
Travis_K
Travis_K UltraDork
10/8/13 2:16 a.m.
Where is the final drive marked on the transmission? I will have to check the rear diff and see what it says. It would be nice if its a common one, not having to swap the rear diff too would be nice.
JohnyHachi6
JohnyHachi6 Dork
10/8/13 2:56 a.m.
Any other subaru trans with the same clutch type (pull vs push) and the same final drive should work, IIRC:
Transmission List
7S8uGmC7MoikJfDrA1xnH8iCvbNNEifQYfVzfKbDByForakk6h0fI0PgRzsxvAsJ
