Tyler H
Tyler H Dork
4/21/09 1:46 p.m.
I picked up a 'recession-friendly' Miata project last weekend. It has been sitting in a shed, without a top, for over a year.
The inside smells like a mixture of mushroom, soil and mildew. If you've ever been to a junkyard (who hasn't?) then you know exactly the smell I'm talking about.
What is the best way to eliminate this funk and keep it from returning? (Aside from fire.)
I'm thinking about taking out the seats/interior and pressure washing them. I was inspired to do this by a post or article I read on here. If you recall the issue or the post, please post up.
Similarly...if you have experience pressure washing interiors, let's hear about it.
Thanks!
belteshazzar
belteshazzar Dork
4/21/09 2:02 p.m.
yup. take 'em to the local diy carwash and go to town. Then leave them out in the sun as long as possible.
YaNi
YaNi Reader
4/21/09 2:04 p.m.
I would pull the entire interior and pressure wash it. I used the carpet machine cleaner, a pressure washer, and a stiff scrub brush. You could probably use Woolite instead. Rinse off carpet, spray on soap/cleaner, scrub til your arms fall off, rinse again. The carpets in my RX-7 are as clean as they're ever gonna get, just need to get it running now...
You might want to clean the floorpan with something while you have the carpet out. Something could be growing on the tar sound deadener.
bludroptop
bludroptop Dork
4/21/09 2:06 p.m.
June '07 - Trash to Treasure issue
Tyler H
Tyler H Dork
4/21/09 2:20 p.m.
Perfect...I'll go pull that issue. Thanks!
RossD
RossD Reader
4/21/09 6:42 p.m.
It might be worth it to get the covers off the seats and get them nice and cleaned up (dry cleaners?) and then you can get to the smelly foam that it was covering. Or maybe its not worth it, I've never had to reassemble a seat.
InigoMontoya
InigoMontoya Reader
4/21/09 9:07 p.m.
Also the bissel little green hand held cleaner does wonders. Do also look into cleaning out any of the AC/heating system vents, you want to make sure some of the funk is not coming from those as well.
Tyler H
Tyler H Dork
4/21/09 9:15 p.m.
Pressure washer did wonders. This seat fabric has held up well to be 20 years old. Maybe it was to cocoon of funk they were encased in? Kinda like funky cosmoline.
RossD
RossD Reader
4/22/09 6:58 a.m.
I watched Wheeler Dealers last night and apparently Edd China throws out dank miata seats and just replaces them from different miata.
Kramer
Kramer Reader
4/22/09 8:45 a.m.
OxyClean bleach alternative kills mold and mildew, just as regular bleach does, although the OxyClean won't kill the color. I've used this stuff to clean grout on my bathroom floor. It would probably help in your sitch.
Joe Gearin
4/22/09 9:33 a.m.
When I bought my rat miata it was pretty odoriffic. After taking the seats out, I shampooed the carpet, scrubbed, rinsed...repeat, then repeat again. My car still had a top though, and the carpets came clean without too much effort. This helped get rid of the odor, but a really thorough detail was needed as well. There was gunk, and stick goo in every conceivable place.
It may be a better idea for you to remove the carpet, and replace. Mold can be nasty, unhealthy stuff.
There's plenty of cleaners and products that will work, but there is no getting around the elbow grease part of it.
Also, make sure the drain pipes that empty near the rear wheels are unclogged. We just had a NA Miata stop by the office with nasty rust holes caused by clogged drain pipes. It is a pretty common problem, and an easy fix.
Duke Dork
4/22/09 9:50 a.m.
Also, get giant cans of aerosol deodorant like Right Guard and go to town on the undersides of the seats, the carpet padding, etc.
Tyler H
Tyler H Dork
4/22/09 10:12 a.m.
RossD wrote: I watched Wheeler Dealers last night and apparently Edd China throws out dank miata seats and just replaces them from different miata.
That would be nice, but I'm balling on a budget. :D If you get over a couple hundred bucks in rehab expense on a $850 car, it becomes better to buy a parts car.
Tyler H
Tyler H Dork
4/22/09 10:14 a.m.
I think it is just barn must. After a thorough cleaning and drying, it will go away.
belteshazzar
belteshazzar Dork
4/22/09 10:17 a.m.
Staying dry and letting the sun kill everything oughta be enough.
EUkZSYx8Q15UXWzZg43TaZGElcXtVswwVj0C2V3FmlK4IRCrkESu9We034FQHIRn
